AbstractDigestAuthHandler does not support 'Negotiate'
3 REPLIES 3
asphaltmania
3810 Views, 3 Replies
Hi all,
I was about to give Fusion a try and downloaded the installer, after it initializes, a popup box came up saying:
AbstractDigestAuthHandler does not support the following scheme: 'Negotiate'
And it quits.
I googled a bit and it seems it has something to do with python (i have a program on the computer that uses python). But I'm not a programmer and don't know what to do about it.
Anyone has any idea? thank in advance! attached is the error log.
3 REPLIES 3
innovatenate
in reply to: asphaltmania
I noted in the log file that an http error 407 occurred. This may indicate that a proxy authentication may be required. Are you behind a proxy server? You may want to review the below link to configure the proxy server.
How to resolve network connectivity problems for Fusion 360
Please let me know if this helps or if you are still having problems installing Fusion 360.
Thank you,
Nathan Chandler
Principal Specialist
asphaltmania
in reply to: innovatenate
Thanks for the info. I do have a proxy in the office. I'll try to install it from another place and see if it works and let you know.
On the other hand it might be a good idea to implement a simple connection setting in the installer since some companies are using proxy and if my computer wasn't a mobile workstation it'd be a bit painful to move it around.
Hello, Sir
I made the steps as recommended in the article, but problem remain 😞
I have already installed the software at home, on my personal pc, but I would like to practice also at work office. Hopefully there will be some solution, you be able to help with.
Reference information below:
Computer : Dell Precision M4800
Operating system : Windows 7
Software I want to install: Fusion 360
Error during installation: AbstractDigistAuthHandler does not support following scheme: NTLM
Sincerely,
Tatyana
