Heidi
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Install HEIDI ???
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
116 Views, 1 Replies
01-14-2005 05:22 AM
How can i install HEIDI driver to my computer. Please , can you explain step by step because i confused so.
I download and unzip HEIDI V8.1.
I install MICROSOFT VISUAL C++ TOOLKIT 2003.
I don't know what i'll do now.
Thanks.
Thanks.
*Michael Butler
Re: Install HEIDI ???
Options
- Highlight
- Email to a Friend
01-18-2005 11:08 AM in reply to:
saudek
If you are using an Autodesk product that requires Heidi, no additional
steps are required to install Heidi drivers.
The Heidi SDK is useful for experienced developers who want to write
applications using the Heidi graphics API.
Listed below are the steps from the Heidi 8.1 SDK Readme.txt. You don't
need to install Heidi drivers - the Heidi DLLs are loaded automatically if
your PATH environment variable is correctly set.
Michael
Heidi 8.1 SDK Readme - 6/11/2004
Open help\index.htm for Heidi HTML documentation.
To build Heidi samples apps using Microsoft Visual Studio .NET:
1. Configure Visual Studio environment variables (run vsvars32.bat).
2. Set required Heidi environment variables (assuming you unzipped to c
- set HEIDIVER=8
- set HEIDIBIN=c:\HeidiDK\bin\i386\Release
- set HEIDILIB=c:\HeidiDK\lib\i386\Release
- set HEIDIOBJ=c:\HeidiDK\obj
3. Set optional Heidi environment variables.
- USRCFLAGS (additional compile flags)
- USRLFLAGS (additional link flags)
4. Add Heidi directories to PATH.
- set PATH=C:\HeidiDK\bin\i386\Release;%PATH%
5. Open sample application in Visual Studio.
6. Build release target.
7. Run.
Note: the unittest sample app depends on the "default" project. Build
samples\unittest\default\default.vcproj before running unittest.exe.
"dinamik" wrote in message
news:19691332.1105709000663.JavaMail.jive@jiveforu m2.autodesk.com...
> Thanks.
