• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Heidi
    Distinguished Contributor
    HP 650C problems
    626 Views, 2 Replies
    04-14-2008 09:35 AM
    Ive got a few problems here. First and biggest problem is we cant plot any aerials. when i send the aerial, it takes about 45 minutes and will then start plotting bits and pieces and then say out of memory. I dont think we are using a Heidi driver as i cant create or modify my paper sizes.
    Next problem, most drawings take between 5 and 10 minutes for the plotter to receive the drawing and start plotting. Is this normal?
    3rd problem, we plot a lot of drawings in .pdf and send them out to get plotted. I can open the .pdf and send it to our plotter and it plots fine. The document center we send it to has to use an E-size paper to plot a D-size drawing. Then they charge us for the E-size. I'm guessing this is a problem on their end and not ours? But is there anything i can tell them? I think they use a HP 1050 plotter unless they got a newer one.
    Please use plain text.
    *Dean Saadallah
    Re: HP 650C problems
    04-18-2008 08:39 PM in reply to: black95gt
    HP650c is your problem: a tired old plotter not capable of handling large
    plot files (Aerials).
    Call and talk to the document center about what the actual problem is, or
    find another location to do your plots if the issue is not resolved, maybe
    at least the second place can explain what the problem might be or just fix
    it.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    04-24-2009 02:15 PM in reply to: black95gt
    Tell your driver (it's in the settings) to spool in your computer instead of the plotter.
    Bryan_S
    Windows 7 Home Premium SP1
    3.60 GHz AMD FX-4100 Quad-Core 64bit / 6gig ram
    Nvidia Gforce 9600 GT O.C.
