• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Heidi
    *RGA
    HDI Driver Availability
    132 Views, 2 Replies
    04-05-2003 10:29 AM
    Where I work, I am having a dispute with our computing support person. He
    knows little about Autocad and I am having a hard time convincing him that
    Autocad requires unique drivers. He wants to get a new printer for our
    office but does not understand why Autocad should have any special
    requirements. I have told him that to get Autocad to print properly, I need
    a printer that is:
    listed as an Autocad supported model or
    has HDI drivers available or
    has Optimized system printer drivers or
    has HPGL/2 or PCL capability
    He says he has talked to several printer manufacturers and they say that
    Autocad will print "just fine" using the standard Windows system printer
    driver. I have told him that this is somewhat true, but that a better
    quality print is available if Autocad specific drivers are available. I have
    said there is also the aspect of greater plotting options
    Is anyone aware of any Autodesk documentation that deals with the merits
    of using the Heidi driver for hard copies? Can anyone offer any additional
    benefits of using specific drivers? Is there a comprehensive list of
    companies and printers using the Heidi technology?
    RGA
    Please use plain text.
    *Sheppard, Scott
    Re: HDI Driver Availability
    04-07-2003 02:09 AM in reply to: *RGA
    Windows system printer drives are generic. Sometimes they do not report the
    actual printable page size correctly. AutoCAD originally had ADI drivers
    because there was no standard for devices. When windows system printer
    drivers became the standard, you would think the need for its own driver
    would have gone away. This was not true due to limitations with wide format
    devices. So ADI was replaced with HDI and the tradition continues.
    "RGA" wrote in message
    news:76E6ACF4B8BA1888F39B761B7FF83D18@in.WebX.maYIadrTaRb...
    He
    need
    > a printer that is:
    that
    have
    merits
    *Fjerstad, Rob
    04-09-2003 04:16 AM in reply to: *RGA
    Ron,
    There are a number of reasons/advantages from going with an optimized
    plotter driver for AutoCAD over the system printer drivers - one is quality
    but there is also performance considerations.
    For small format printers, it probably doesn't matter, most system drivers
    are ok unless
    - you have a very slow network. HDI drivers often produce smaller plot
    files.
    - you need to use virtual pens, which plain system drivers do not support
    For large format devices it is more likely to make a difference.
    1) Heidi drivers (or optimized system drivers with back doors) are less
    likely to run out of device memory than plain system drivers.
    2) they usually do a better job of handling drawings with large amounts of
    raster
    3) in some cases they may offer better plot quality and speed for CAD
    drawings than plain system drivers
    In short, the best plan is to try plotting some of your typical drawings to
    the device you are considering buying, using the driver that is available
    for it.
    -Rob
    > Hi,
    He
    need
    > a printer that is:
    that
    have
    merits
    > Thanks
    > RGA
