Hardware
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
RAM size for multi Autodesk products
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am using Autocad Electrical, inventor, Vault and other Microsoft Windows office application. I am wondering what size of the RAM I should be using. and I am currently using 4G RAM, is it too low?
Lei
Re: RAM size for multi Autodesk products
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For Inventor, definitely. For 64 bit Win 7, definitely. RAM is relatively cheap - find out what your motherboard can support (typically in the 16 - 24 GB range) and max it out.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what exact OS are you using?
what is your processor?
while RAM ia relatively cheap, it may still be a waste of money if the OS is the limit. And while "maxing out" sounds good, since you must be doing ok with 4G perhaps 8G is all you might want to consider unless therest of your hardware is worth the effort of "max".
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OS is Windows 7 enterprise; intel core i7-2620M cpu 2.7GHz, 64 bit OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So it's all new, great: explore installing at least 8Gig as a minimum from now on, find out what your system can hold as a mx and determine if it's worth it based on your actual usage of your software (light user=pointless, heavy user=consider more, Uber-Power user that people go to for advise for all that software=max out).
With 3D, if you render, vid card becomes important too.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Using Inventor isn't what I'd consider light use, hence the immediate recommendation ![]()
Also, If by "render" you mean "to file", then video card doesn't really come into it - thats all RAM and processor speed I think we're still a generation or two from being able to send data to a video card and having the graphics processor there duplicate the "on screen" image back to the CPU. The video card comes into play for real-time navigating through the model while designing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My AutoCAD got shut down by Windows many times everyday. It usually happens when I plot the project to PDF. It is worse if I plot a project containing more than 10 drawings, and works better if i plot prjects containing less than 5 drawings.
I suspect the root cause is the RAM. I may need a bigger RAM.
Betreff: RAM size for multi Autodesk products
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello FengLei70 and List,
this Question is perhaps a "easy to ask" question, but not even so easy to be answered, but perhaps the following lines are helping you to go step by step to solve and configure it out. I´ll hope that helps you a little bit and please
don´t bother with me because my english is not verry welformed, I´m naturally german speaking.
Ok, here we go:
Best of all start at the basement, that means your mainboard, than the OS and than the Software, so for most peoples it becomes more logical.
Hardware:
Mainboard:I´ve a mainboard from EVGA named SR-X with two LGA 2011 Sockets and two Intel Xeon E5-2690 CPU´s. The mainboard is capable to hold a maximum of 96 GB RAM on 12 RAM Slots, point not more and not less.
So that means I can´t install more ram because the RAM must also be adressed by the TAG RAM chip on the mainboard to make him reachable for the OS.
CPU´s: The CPU´s I am using are sorted with 8 real and 16 logical cores normally you should count for each real core (not the logical cores) 2 GB of RAM, that is like 16 real cores x 2 GB RAM = 32 GB RAM is a moderate count!!!!!
RAM Channel architecture: Later not jet please.
Operating System:
In all three variants (Professional, Ultimate and Enterprise), Windows 7 / 64 Bit is supporting of TOTAL 96 GB RAM,
that means the Video Card RAM and the normal RAM on the mainboard.
That means if I have a Videocard setup as an example
like the following shown in the next line I have to, it is not a can do, it is a must do, calculate this to the on the mainboard installed RAM!!!!
Example: 2 x nVIDIA Quadro 6000 SLI and 2 x Tesla C2075 each Videocard has 6 GB RAM, that means for us now
4 Videocards x 6 GB = 24 GB
All in all now we have 32 GB to fit the needs of the CPU power and 24 GB of Videocard RAM that is a total
32 + 24 = 56 GB Point not more and not less!!! If the mainboard is supporting 96 GB of RAM and also your OS
(Windows 7 / 64 Bit Professional, Ultimate or Enterprise) is also doing support 96 GB of RAM and now you have 56 GB of RAM, you are not so many over dosed and inside the hardware and OS supported range.
I consider to the first answer from "dgorsman: RAM is cheap", with the following example.
Before some month a DDR3-1600 Quad Kit with 16 GB of RAM (4 x 4 GB modules)was at 249 - 269 Euro´s here in Germany, but now today at the same time I wrote this lines to you, this Quad Kit is "only" for 192 Euro´s able to buy!!!!
Now we have to keep an viewing eye on the some lines above, what kind of RAM channel architecture your mainboard is supporting. The EVGA SR-X is supporting quad channel DDR3 RAM kits, I was taken the
3 x Corsair DIMM 16 GB DDR3-1600 Quad-Kit (CMP16GX3M4X1600C7, Dominator) that means I have now 12 RAM modules with 72 GB of total RAM, point not more and not less.
With the 24 GB of RAM from the Videocards, that means 72 GB + 24 GB = 96 GB all is configured out at the status of calling the maximum.
This is only an example setup to show you up what I am meaning with my words, because my english is not so verry welformed!!!
At last but not least there is a another very important thing, that helps you to keep all, the hardware, the OS and the software, smooth going and let the whole assemble play easy together, the HDD and the case.
For the example setup here owed to the 4 Videocards and the heat they are producing!!!
Case:
Also for our example avbove, it should be a Zalman GS 1200 (HPTX mainboard capable) because on the left side of the case there is a very huge and big ventilator of ~ 200 mm, it turns slow and is not noisy and deliveres steadily fresh air to the Videocards, if not and the CPU´s trotteling down to a slower speed tact rate!!!!!
HDD´s:
First let us talk about what kind of setup we are using above, I mean low, medium high end or ultra high end,
so I mean this is something between high end and ultra high end and that we have not an bottleneck in the system
we should also go by very fast hdd´s with now raid please, but there fore later.
Also very important is the Software you are using and what you are doing with this software and also in witch succession or order.
Normally peoples should by a fast HDD that is fitting their needs of speed and space, but I think better that the hdd´s
is similiar to the rest of the hardware, of the machine. For our example above perhaps a Samsund 830 series
with 512 of RAM. So you now perhaps asking you self why sould I buy a so big hdd, but the answer is also so easy how bigger a SSD is, how faster will be the wright and read sequences.
But if a program will be started and the code goes through the CPU and will be placed in the ram and you are using inventor and this program can make really great, big or heavy files and the ram is not enough or better you are running out of the RAM, than the data will be written to the hdd, in the swap file called pagefile.sys or something like this, normally it called "swap". So if we are using a 512 GB Samsung 830 for the OS and the programs, we should use one or two 64 GB hdd´s to point the swap file on, better two if you are working on inventor huges files.
So if the OS + program hdd is a fast one and the swap hdd´s are slower (cheaper) ones, so have created the next bottleneck in the system!!!
As another example, perhaps you go the way AutoCAD > Inventor > 3ds Max > Photoshop, only as an example!!!!
and you are using the Photoshop for post production work or for what ever else, this program is also be able to setup temp folders and this temp folder should not be on the same hdd as the system and the swap hdd´s,
so for lower picture resolution some one should be a fine thing, but if you are working with greater files
and you are using plugins and somthing like blur than you should have two or more hdd´s for setting them up as temp space.
At last please accept that the most things are purely fast pointed to one or more things like not enoough ram or something else and also considering to the last message from "dgorsman" he is speaking about rendering on the machine, perhaps as shown in some lines above (3ds Max) this Videocard setup is hard enough, but what you are using for a Videocard, are you rendering?
So sorry for the massive writing here to a so easy part, (RAM) perhaps you sould look in the mainboard manual of your machine, count the real cpu cores, what kind of ram maximum and sort (DDR1,DDR2 or DDR3) your mainboard is supporting and you can go and buy "cheap" RAM modules and let us know what is going on after the RAM upgrade.
I hope it was helping you a little bit
Chears and good luck from Germany
Raoul
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is great technical writting! I think I understand more of this issue with the help from you and other helper who make comments on this thread. Either me or our IT guy will look into the mainboard structure, and maybe add more RAM if applicable.
The thing that I am still stuggling with is why Windows shut down a software like AutoCAD, even if we run out of RAM, that only means OS will have to do more "context switch" between hard drive and RAM, which will slow the system down for sure. I can understand the "slow down", but why "shut dow"?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
About the only time I've seen plots shut down is due to the content of the files (dense hatching, renderings, image files etc. that bulk up each plot file size during processing) and not the number of files: RAM is the short term may fix it until you hit the next level of limitation.
What is the typical PDF size output from one of these publish functions?
Do you use background publishing at all?
