Hardware (Read Only)
RADON HD 6350 Graphics Dual DVI Adapter with Autodesk Inventor
3 REPLIES 3
1423 Views, 3 Replies
Will the AMD RADEON HD 6350 Graphics Dual DVI Adapter work with Autodesk Inventor in a Dell Optiplex 990.
OptiPlex 990 Minitower Core i7-2600, 3.4GHz, 8M, VT-x, 95W, Optiplex 990 8GB,Non-ECC,1333MHz DDR3,2x4GB,Dell OptiPlex 990
Tom
3 REPLIES 3
TravisNave
The Radeon 6450 is approved and certified, but not the one you list.
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880&results=1&product_group=12&suite...
I would recommend a workstation class video card with WHQL certified driver.  You will probably have better luck with nVidia over AMD.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
The 6450M has been certified, which is a laptop.  The 6450 for a regular PC has not.  Hmmm now what the difference?
TravisNave
One is a mobile architecture and one is a personal computer architecture.  They are driven by separate drivers and are not interchangeable.
Autodesk Forums:
