Hardware (Read Only)
New computers for Inventor, AutoCAD, AutoCAD LT
16 REPLIES 16
Message 1 of 17
2660 Views, 16 Replies
I have been tasked with finding a spec for a new computer to run AutoCAD LT 2012. We have a reasonable turnover of staff and project requirements so it needs to be a decent spec for our Inventor use as well if and when the time comes. We have 4 top workstations for our full assemblies and Inventor Routed Systems use.
My manager has strongly suggested Dell as he has purchased from them before, although we may go through our Autodesk reseller who I believe would provide an HP.
Here is a Dell  Precision T1600 spec I put together, does anyone have any thoughts to it? Its under £800.
Processor - Intel® Xeon® E3-1225 (Quad Core, 3.1GHz, 6MB, 2GT)
Microsoft Operating System - Windows® 7 Professional (64Bit OS)
Memory - 8GB ( 2x4GB) 1333MHz DDR3 Non- ECC
Hard Drive - 250GB 3.5inch Serial ATA III (7.200 Rpm) Hard Drive
Optical Devices - 16 x DVD+/ -RW Drive
Video Card - 512 MB NVIDIA Quadro 400
Would an i7 processor be a better option?
My manager did come back with a spec for a Dell T3500, which comes in at just over £900:
Processor - Intel® Xeon® W3530 (Quad Core, 2.80GHz, 8MB, 4.80GT/s Intel QPI)
Memory - 3GB 1333MHz DDR3 ECC
Hard Drive - 500GB 3.5inch Serial ATA III (7.200 Rpm) Hard Drive
Video Card - 512 MB NVIDIA QFX 580
Looking around I have a feeling that a i7 config would give us a much better spec for the price.
Simon
Tags (2)
16 REPLIES 16
Message 2 of 17
pendean
If you are going to drop down to 3Gig RAM/memory, you might as well keep your old PCs, there is no point in upgrading.
Message 3 of 17
in reply to: pendean
I told my manager that 3GB is simply not enough. I suppose I am really querying whether Xeons and ECC are important, or if a faster i7 with more RAM is better for the same money. Also we have a quadro 370 lying around that should be fine for AutoCAD LT? it's just simple 2D wiring diagrams..
Message 4 of 17
pendean
A speedy two-seater car is still, well, a tiny cramped incovenient low-ram two-seater: AutoCAD perfers speedy RAM-roomy sedans with ample room to stretch.
If you are going to the effort of buying a new PC, 8Gig with Win764bit is a minimum standard configuration: processor speed matters to AutoCAD to a point with 2D drafting, but you did throw in there an Inventor requirement so you are doing more than that, correct? In which case your video choices are on the low end.
Since price seems to be your manager's deciding factor, stick with the i5 and seek out a better graphics card: search around here for recs.
Message 5 of 17
thanks,
So for the AutoCAD LT / Inventor entry computer i5 2500 CPU, 8GB Ram, Quadro 600 1GB vRAM?? or perhaps a GeForce with more vRAM. I think that is easily achievable at a similar price as my first spec in first post.
For more intensive Inventor use, i7 2600 CPU, as much RAM as can fit/afford, Quadro 2000 etc...
What's the reason behind a lot of resellers offering Xeon and ECC RAM as CAD workstations? it would seem as if its really not that important nowadays...
Message 6 of 17
Look at my sig.
With Win 7 64 pro & a DVD writer & Card reader, I brought this in at just under $1400 USD by ordering the parts from Newegg.com.
What I wanted was the WD Velociraptor HD & a decent, mid range video card with Nvidia drivers.  In any new system, make sure the HD & MoBo will accept SATA 6.0 & USB 3.0.  I'm a bit partial to Western Digital drives right now.  My brother builds hard drive making equipment, and has told me that WD is about the most stable out there right now.
8 gigs of ram is minimum now for ADSK products.  sweet spot is betwee 8 & 16 gigs.  SSD's are nice, but not cost effective IMHO.  Better off with a faster HD.  Why don't you look for a local who will build you a system with what you want, not what Dell of HP want to sell you.
Reid
Message 7 of 17
Sinc
It has been quite some time since ECC/Registered RAM has meant anything for CAD workstations.  And Xeons are only beneficial for people who do lots of rendering, and want a multi-CPU machine for that.
If you aren't incredibly concerned with getting absolute maximum rendering performance, and instead want decent rendering performance with the best possible general performance at the lowest possible price, then the 2nd Gen i5/i7 chips would be the way to go.
Sinc
Message 8 of 17
dgorsman
in reply to: Sinc
+1
Xeons and their motherboards are built to do two things very well: manage large numbers of concurrent processing threads, and large amounts of RAM (there's a few high-end Dell workstations with 4x quad core *plus* HyperThreading and max RAM in the 96GB range).  They are also more "fault tolerant" (thus requiring ECC RAM) but with modern manufacturing standards its almost a non-issue outside of computers in critical service.
Most desktop applications won't be making use of either of those features and most businesses only see that on the server-side and even then not that often.  Not sure, Inventor may make good use of the Xeon's benefits for extensive FEA work but thats about it.
Message 9 of 17
Thanks everyone,
I think I have it sussed. I am going to suggest three tiers of workstation based on the requirements within our D.O. All built up by 3XS:
2D / 3D Low End Workstation (AutoCAD LT 2011 & Inventor 2011 Suite light use):
Intel Core i5 2500K, 3.3Ghz, Quad Core, 6Mb Cache - overclocked by our 3XS engineers to 4.5Ghz
Asus P8P67 LE Rev3, Intel P67 - USB3 & SATA6 Support
8GB (2x4GB) Corsair XMS3 DDR3, DDR3 1600Mhz
1GB PNY Quadro 600
500GB Western Digital, Caviar Black, SATA 6Gb/s 32MB Cache
Microsoft Windows 7 Professional 64 Bit
£832 ex.VAT
3D Mid Level Workstation (Invnetor 2011 Suite use):
Intel Core i7 2600K, 3.4Ghz, Quad Core, 8Mb Cache, Hyperthreading - overclocked by our 3XS engineers to 4.5Ghz
Asus P8P67 Rev3, Intel P67 - USB3 & SATA6 Support
8GB (2x4GB) Corsair XMS3 Classic, DDR3 1600Mhz
1GB PNY Quadro 2000
600W Corsair CMPSU-600CX Builder Series
£1127 ex.VAT
3D Top Level Workstation (Invnentor 2011 Routed Systems / Large Assembly use):
16GB (4x4GB) Corsair Vengeance DDR3 1600Mhz
2GB PNY Quadro 4000
£1470 ex.VAT
Check my sig for what my manager spent £1400 on for our top end workstations about 6 months ago...
Message 10 of 17
sam_m
in all honesty I'd drop the Quadro cards and save more cash (and actually have a quicker graphics card)...  With regards to Inventor, it switched to DirectX from OpenGL a few years ago and with it the need for OpenGL-enhanced workstation cards has gone out the window.  I'd be looking at a GeForce 560TI if I was to build a system today (for decent performance/price ratio)...
Due to the setup being DirectX you can use a generic DX benchmark (like Passmark: http://www.videocardbenchmark.net/high_end_gpus.html ) to gauge the performance of the Quadro cards against the GeForce.  As a comparison a Quadro 2000 (about £300) has nearly 1/3 the DirectX performance as a GeForce 560TI (about £180).
We no longer use AutoCAD or MDT in anger, but have not had a problem with our "gaming" graphics cards when we do.  And, looking at OMCUSNR's sig, he is using (and recommending) a gaming card too (GTX 460).
Just make sure to keep your drivers up to date (not just the Nvidia gpu drivers, but motherboard, etc. too).
Only other comment, I might be looking at a SSD system hard drive as a few members in the Inventor forum are noticing a vast performance increase with them.  If you need 500gb for local storage then have that as a 2nd drive and a small(ish) SSD as your main OS and software drive.  Just something else to think about.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 11 of 17
Sinc
in reply to: sam_m
If you go with an SSD, just keep in mind that even a 120GB SSD primary hard drive can get cramped relatively quickly on Win 7 x64.  I definitely wouldn't try anything smaller than that.
Sinc
Message 12 of 17
in reply to: Sinc
Currently we are loading files directly over gigabit network so maybe the SSD route wouldnt be that much of a benefit now? I am strongly campainging the implementation of vault and I am sure that SSDs would give us great benefits in that situation, perhaps it is worth trying to include them in order to future proof the workstations considering the cost saving route of i5/i7 chips nECC RAM and gaming GFX cards etc...
Message 13 of 17
Sinc
The main benefit of the SSD is that it loads the OS and applications much faster.  It also speeds up temp file access, which Autocad tends to do a lot of.  It definitely makes an improvement, it's just that getting a large enough SSD is still relatively expensive.  It's more worth it for laptops, where you get added benefit from the cooler operation and lower power consumption.
I suspect that in the next couple of years, SSDs will start to become relatively standard for primary drives.  At the moment, they're still on the fence, due to price.  If you feel comfortable with the price, they definitely improve performance.
Sinc
Message 14 of 17
dgorsman
in reply to: Sinc
+1
SSD is great for one-off or personal computers but for mass purchases of business computers the extra cost adds up faster than the benefits.
I'm somewhat dubious of claims of "vastly speed improvement with an SSD", as I think many are doing a full system change, or even a fresh wiped system, rather than just changing over from a conventional drive to an SSD.  Add perception vs actual numbers on top of that and the value of the statement is questionable.
Message 15 of 17
in reply to: dgorsman
Thanks everyone,
Here is my latest configurations that I will suggest to my manager:
Intel Core i5 2500K, 3.3Ghz, Quad Core, 6Mb Cache overclocked by our 3XS engineers to 4.7Ghz
8GB (2x4GB) Corsair Vengeance, DDR3, 1600Mhz
1GB EVGA GTX 550 Ti FPB, 951MHz GPU, 192 Cores, 4356 Mhz GDDR5
500 GB Samsung Spinpoint F3, 7200 rpm, 16MB Cache
£746 ex.VAT
Intel Core i7 2600K, 3.4Ghz, Quad Core, 8Mb Cache, Hyperthreading overclocked by our 3XS engineers to 4.7Ghz
1Gb EVGA GTX 560 Ti SC, 900MHz GPU, 384 Cores, 4212Mhz GDDR5
120Gb OCZ Vertex 3 SSD, Read 550MB/s, Write 500MB/s
Microsoft Windows 7 Professional 64 Bit - OEM
£1017 ex.VAT
16GB (4x4GB) Corsair Vengeance DDR3 DDR3 1600Mhz
1536MB EVGA GTX 580, 772Mhz GPU 512 Cores, 4008MHz GDDR5
600W Corsair Builder Series (Single Graphics Card)
£1363 ex.VAT
A lot of what I have read on the web generally has said the SATA3 HDDs won't give that much of an improvement over SATA2 drives mainly due to the mechanics of the drive and that SATA3 was mainly developed to harness the speed of SSDs.
We are also a small enough DO that SSDs for the 3D guys is probably a viable option. We aren't doing a full upgrade of hardware, we have immediate requirement for a couple of the low end models, but generally these will be reccomendatins for new staff as and when we hire...
Thanks for all the advice. Keep the comments coming if there are any.
Message 16 of 17
Sinc
I kind of think the GeForce 550 Ti is a bit of a rip-off.  If you can find something like a GeForce 460, 460 SE, or 465, you'll probably spend about the same amount for a card that works a fair bit better.  Otherwise, the 550 Ti will work.
Yes and no on 6Gb/s SATA (a term that is preferable to SATA3, since SATA3 is so easily confused with 3Gb/s SATA, aka SATA2).  It depends on what you're doing, and on the cache size of your drive.  If you have a fast 6Gb/s SATA drive with 64MB of cache, then you can see better performance on writes of small files, since the entire file can be sent over the 6Gb/s SATA wire and stored in the cache on the drive.  You're still limited, though, in that if the cache fills up, you're back to slow write speeds until the drive can catch up.  And the 6Gb/s doesn't help much for read speeds, which are typically limited by the drive itself, and not the connection.
So yes, the 6Gb/s is only really helpful with these fancy and fast new SSDs, but it can help a bit with mechanical drives in limited situations.
Sinc
Message 17 of 17
in reply to: Sinc
Thanks Sinc.
Here's the configured option from 3XS that uses a 460 SSC instead of the 550 Ti
Intel Core i5 2500K, 3.3Ghz, Quad Core, 6Mb Cache overclocked by our 3XS engineers to 4.5Ghz
8GB (2x4GB) Corsair XMS3 DDR3, DDR3 1600Mhz CAS 9
1Gb EVGA GTX 460 SSC, 850Mhz GPU 336 Cores, 3900Mhz GDDR5
£750 ex.VAT
It does get quite a bit better passmark score compared to the 550 Ti for not much price - good call...
