Hardware (Read Only)
Logitech MX Revolution - Pan
21 REPLIES 21
Message 1 of 22
2155 Views, 21 Replies
I'm a sucker for new gizmos, so I now have the new MX Revolution thingy from
Logitech in my palm.
Well guess what, with two scroll wheels at your disposal, you are not able
to make one of them go pan in Autocad or Inventor. I've tried setting the
"normal" wheel to autoscroll and middle button and every other setting I
could find, but no luck.
I now there has been some issues earlier with Logitech mice and pan, but I
believe I've tried all solutions now.
If anyone know a solution to the revolution I would be very happy.
I had also hoped the thumb wheel colud be set to whatever you want, but this
has only a zoom function and program switch.
Still not 100% optimal ergonomics in my opinion, but the best so far.
Battery capasity is very poor from what I can tell from my limited use til
now.
Jorgen
21 REPLIES 21
Message 2 of 22
One more thing...double click the middle button (wheel) will not zoom
extents in Autocad either.
Jorgen
Message 3 of 22
I found the answer now, right after posting. This fixed both pan in Autocad
and Inventor as well as dbl click to zoom extends in Autocad. Phu!
http://forums.logitech.com/logitech/board/message?board.id=general_mice&message.id=1170
Jorgen
"JGH" wrote in message
news:5320340@discussion.autodesk.com...
now.
Jorgen
Message 4 of 22
darnit... trying to follow the link and I timeout waiting for the server...
will have to try again later...
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com/
news:5320343@discussion.autodesk.com...
and Inventor as well as dbl click to zoom extents in Autocad. Phew!
Jorgen
now.
Jorgen
Message 5 of 22
Setp 1:
-Click the wheel on the left side after Setpoint is up.
-Set the wheel to "disabled (Overrides application settings)
-set on Always click-to-click.
Setp 2.:
-click mouse on the left side
-now button 3 should be "disable"
-select it and select " other" then " middle button".
"melanie stone" wrote in message
news:5321101@discussion.autodesk.com...
Melanie Perry
Jorgen
now.
Jorgen
Message 6 of 22
Thank you! 😄
Melanie Perry
news:5321950@discussion.autodesk.com...
Setp 1:
Setp 2.:
Melanie Perry
Jorgen
now.
Jorgen
Message 7 of 22
How do you like this mouse? Does the SmartShift technology work well?
http://www.logitech.com/index.cfm/products/upp/details/US/EN,crid=2676,contentid=12134&ad=revolution_mxupp
Rick Moore, AIA
www.bgkarchitects.com
Message 8 of 22
After I've spent a few days with it, it now is back in it's box
- Ergonomics. It felt good at first, but after some time I acutally got a
"soar joint" in my hand. I had to stop using it, now I'm ok again....
- The new Hyper-fast scrolling and Smartshift needs to be dispabled if you
want panning to work.
- The side button is well placed, but to no use whatsover. (well at least
for cad work)
- Allmost Impossible to do a dbl click with the scroll wheel to enable zoom
extents in Autocad.
- Battery not that bad that I implied earlier (just had not charged it fully
I believe)
Conclusion:
In my case I can't use it due to the bad ergonomics for cad work. (but this
might be just me)
Also the driver for this mouse need to be updated alot to make it usable for
cad.
Looks nice though!
But please don't hate it because I don't like it. Try it at least.
Jorgen
"Rick Moore" wrote in message
news:5331047@discussion.autodesk.com...
Rick Moore, AIA
Message 9 of 22
Farmboy1
I have just purchased the MX Revolution mouse. I need it to be able to pan and zoom extents on the push of the scroll wheel as you did. I am a full time AutoCAD 2007 technician. Please explain in simple terms how you did it.
Farmboy1
Message 10 of 22
open up your setpoint control panel
underneath the picture of the mouse find the button that says manage
programs
add your acad.exe
select autocad as the program and change #3 to other> Middle Button
done
for some added productivity I made the following changes as well for autocad
4 keystroke assignment "down" for use with dynamic input
5 keystroke assignment "ctrl+"
6 keystroke assignment "shift+"
"Farmboy1" wrote in message news:5524239@discussion.autodesk.com...
Farmboy1
Message 11 of 22
Farmboy1
Cheers Sicko.
Message 12 of 22
No problem.
I need to mention, there might be one other setting to change.
there is a tab on the side specifically for the wheel. Select AutoCAD and
uncheck "allow manual shifting between modes"
"Farmboy1" wrote in message news:5524512@discussion.autodesk.com...
Cheers Sicko.
Message 13 of 22
Farmboy1
Thanks. It's working well now. I am just hoping that the springs in it soften up a bit now. You really have to lean on it to use the press feature on the scroll wheel.
Thanks again
Message 14 of 22
cool. Except now it keeps panning continuously.
"sicko" wrote in message
news:5524847@discussion.autodesk.com...
No problem.
Cheers Sicko.
Message 15 of 22
gladi8or
Hi, I have the same problem in 3D Studio Max 9. The problem of the pan thing seems to be ok in other aplications like internet explorer or office, but when I run the max, pan just dont work. I know that we can select the application to apply the settings but they are all the same for max and other apps. Any ideas about this. Is that autodesk or logitech's fault?
Message 16 of 22
partyanimal
did you ever get this figured out
i just bought this mouse and cannot figure it out
must be something i am not doing correctly
and help would me great
thanks
Message 17 of 22
> thanks
since you didn't quote the original post I don't know what you're trying
to figure out but I use a Logitech Revolution and don't have any trouble
panning. If you are using the Logitech SetPoint software, in the My
Mouse tab select your mouse in #1, select AutoCAD Application in #1A,
select #3 Middle Button in #2, and select the other item in #3 and set
the function to Middle button. That, and set MBUTTONPAN in AutoCAD to
<1> and all should lead to happy panning
Dave
DDP
Message 18 of 22
Turn off the scroll bars in AutoCAD.
Bill
wrote in message news:5749420@discussion.autodesk.com...
thanks
Message 19 of 22
In the set point software, I set the scroll as "generic". After I did that,
it worked fine.
Bill Allen
thanks
Message 20 of 22
PatrickLau17
I have the MX Revolution and have just figured out how to set it up with whatever wheel scrolling settings I want. The important step is to set the scrolling however you want and then change button 3 under the AutoCAD program settings to "Middle Button". For some reason whenever you change the wheel scrolling settings it reverts the button 3 value to "Do Nothing". I truly love this mouse now. I am using "Control Center" version: 4.24.99
