Hey guys,
After continues issues with Geforce GTX 660 TI graphic card while working with Revit and AutoCad I decided to replace the graphic card with a Quadro 4000 today.
Once I removed the old card (uninstalled old drivers) and installed the new card turned on the PC however the PC did not pass the initial bios post (motherboard logo) and certainly did not get into Windows boot up option. Once turning on the PC the motherboard logo (Gigabyte GA-X79-UD3) is shown however it gets stuck and after few minutes the screen goes blank. Whilst the Gigabyte logo is shown I tried to enter the Bios setup to check the settings however cannot enter the setup as the keyboard is completely inactive. I also tried using DVI cable and Display port cable (the only connections available on the Graphic card) to see if it makes any differences but neither made any difference.
Just to cover every aspect I connected this card to various PCI slots that are available on GA-X79-UD3 but still the issue persists. I also disconnected the power cable to some of the peripherals just in case if there is not enough power available but that did not make any difference as well. Technically the power requirement for Quadro 4000 should be less than GTX 660TI.
Any ideas on how to fix this? There has to be some sort of conflict that does not let the PC to boot but there is no beeping sound from the PC to support this.
Did you plug in a power source to the card itself? My Quadro cards have additional power port on the end.
If you put the old card back in, does your computer work again?
Do you have a USB hub, or a USB port on a keyboard or monitor? I had similar issues with my Gigabyte MB, where the boot was failing due to a device-located USB connector. Although I solved it by using a basic keyboard without a USB hub, apparently plugging in a memory stick or similar would also solve it.
try posting on nvidias forum
it might be a bad card
DarrenP
what psu have you got?
as far as i can see the 660ti takes a max of 130W but the Quadro 4000 is 150W so you could well be on the cusp of what's needed. I'd probably want a decent (named brand) 600W (at least) for the Quadro, depending what else is in the system.
Could also think about booting with the GeForce and update motherboard bios? Just in case it's something there which is causing the problem.
Also might be worth setting bios options to defaults before swapping cards, in case someone has spec'd specific voltages, timings and settings for the GeForce which the Quadro isn't happy with.
Any other pcs about? can you try the card in one of them - if it POSTs then it's not the card being defective...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
