Hardware (Read Only)
HP Laserjet 5000, Windows 7, and AutoCAD 2002 LT
6 REPLIES 6
icords
613 Views, 6 Replies
The plotter manager does not list the HP Laserjet 5000.  I can print using the currently installed driver from every other program, but I can not plot from AutoCAD 2002 LT.  Any and all suggestions appreciated.
6 REPLIES 6
pendean
in reply to: icords
there is a box you need to uncheck in OPTIONS command, PLOT tab, titled HIDE SYSTEM PRINTERS.
icords
in reply to: pendean
Unfortunately that box was already unchecked.
I was able to find a solution.
I copied the .pc3 file from my 32bit XP system and pasted it into the plotter manager of the 64bit Win7 system.
Bada Boom Bada Bing....It works!
Learn it, use it, save it!
cpbustamante
in reply to: icords
Hello! I would just like to ask how did you manage to install your HP LaserJet 5000? Sorry if this is Off-topic!
thank you
pendean
in reply to: cpbustamante
Go to HP.COM and get the Windows Universal Driver and install it on your PC like you do all printer drivers. Now PLOT to it from AutoCAD.
cpbustamante
in reply to: icords
I tried that. May I ask how is your printer connected to your PC?
Are you using a parallel to USB connection?
pendean
network printers: your problem may be your choice of cable connection.
