Hi All,
Does anyone know if the card nvidia quadro K4000 supports rendering in autocad architecture 2010?
I found a lot of drivers for other autodesk softwear but nothing for architecture.
How best to set the card to use it in AutoCAD? Anyone could help?
I put below a log from settings.
Performance Tuner Results Log Version: 18.1.0.2 Date of Last Tune: 2013-05-15 Machine Configuration --------------------- Processor Speed : 2.3 GHz RAM : 32694 MB 3D Device --------- Name : NVIDIA Quadro K4000 Manufacturer : NVIDIA Chip set : Quadro K4000 Memory : 2722 MB Driver : 9.18.0013.1090 Your machine contains a 3D Device that is not certified. As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website. You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button. Current application driver: acaddm10.hdi Current Effect Status: ---------------------- Enhanced 3D Performance: Available and on Gooch shader: Available and using hardware Per-pixel lighting: Available and on Full-shadow display: Available and on Texture compression: Available and off Available application drivers and effect support: ------------------------------------------------- Software driver Effect support: Enhanced 3D Performance: Not applicable Gooch shader: Software emulation only Per-pixel lighting: Not applicable Full-shadow display: Not applicable Texture compression: Not applicable Direct3D driver: Not Certified Effect support: Enhanced 3D Performance: Available Gooch shader: Available Per-pixel lighting: Available Full-shadow display: Available Texture compression: Available Enhanced 2D Performance: Available Autodesk driver: Not Certified Effect support: Enhanced 3D Performance: Available Gooch shader: Available Per-pixel lighting: Available Full-shadow display: Available Texture compression: Available Enhanced 2D Performance: Available
It should be find. Here is a WHQL certified driver. Your Autodesk driver database likely is outdated so it won't show as certified, but you can override any setting it disables.
http://www.nvidia.com/object/quadro-tesla-grid-win8-win7-winvista-64bit-320.00-whql-driver.html
I'm assuming Windows 64-bit here...
DarrenP
You need to take the Autodesk "Recommended" drivers and cards with a grain of salt. For example, if you have a quadro 600 and you check the Autodesk website, it may tell you a driver is certified that is a year old. Because once a newer card comes out (like a K600), they don't seem to test any newer drivers on the older cards. So if you want to use the most up to date driver on a card that is a year old or more, the Performance Tuner will say it is not certified. I use a FirePro V5800, which is 2 FirePro generations old. Their recommended driver is from August 2011, but I'm using the newest driver from March 2013 so it says it is not certified. Don't ever hold your breath waiting for Autodesk to catch up to what's current because it's not going to happen.
You obviously have a K4000 according to your screen shot, so you should simply go by if it works well or not. If it's working good then there is nothing to worry about.
