Hardware (Read Only)
Comp 4 Revit 2014
2 REPLIES 2
2451 Views, 2 Replies
2 REPLIES 2
TravisNave
The Dell is no longer a valid link.  The Tiger Direct has too weak of a video card.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
braudpat
in reply to: TravisNave
Hello
For REVIT 2014 on Win Seven 64 bits Pro (or on Win Eight 64 bits) :
- A fast Core i5/i7 (3 Ghz is a minimum if possible)
- 16 Gb Ram
- Win Seven Pro 64 (better than Win Eight 64)
- A "decent" video card : Quadro 1000 (or equivalent from ATI) or more powerful with 1 Gb (or better 2 Gb)
- A very fast HD SATA or better : a SSD (as primary) + a fast SATA (as secondary)
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
