Hardware
New Member
serverbrb
Message 1 of 7 (206 Views)
AutoCAD 2000 Performance Question
206 Views, 6 Replies
10-08-2011 05:39 PM
Hopefully someone can answer a few questions, I have a client that requested I build him a computer specificlly for AutoCAD 2000.  I mainly need to know where to put most the money, does AutoCAD 2000 have any support for GPUs?  As far as CPU can it take advantage of multiple cores, or will it just use one core for everything it does?  How about a faster I/O device such as a 10,000 RPM HDD or a SSD, any benifit there?  If it does not support anything nativly, are there add-ons or settings I can tweak to take advantage of the modern hardware?  I know he does render with the software, if you need any more information from me or him as far as what he uses it for and what hardware I am looking at please feel free to ask.  Thanks!
*Expert Elite*
DarrenP
Message 2 of 7 (175 Views)
Re: AutoCAD 2000 Performance Question
10-11-2011 08:30 AM in reply to: serverbrb
autocad 2000 came out over a decade ago
it won't take advantage of any of the new hardware/technology that is out
*Expert Elite*
pendean
Message 3 of 7 (170 Views)
10-11-2011 12:04 PM in reply to: DarrenP
1999 I believe, for Win95/98.
OP, are you old enough to remember Win95/98 and the software/hardware they could run on? yeah, your iPhone has more juice and ability.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
serverbrb
Message 4 of 7 (142 Views)
10-13-2011 03:48 PM in reply to: serverbrb
That's what I extected, so dual-core with max OC.  I just wanted to make sure there wasn't an add-on or patch that could take advantage.  What about higher I/O, any benifit there or will the CPU bottleneck be so great it'll prevent that from being a help?  Right now I am looking at a dual-core clocked around 3.8-4.1Ghz.
*Expert Elite*
dgorsman
Message 5 of 7 (140 Views)
10-13-2011 04:02 PM in reply to: serverbrb
I question the risk of overclocking, given that an AutoCAD as ancient as the "2000" is significantly lighter than modern versions.  At that speed the primary bottleneck is the meat, not the metal.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Distinguished Mentor
OMCUSNR
Message 6 of 7 (130 Views)
10-14-2011 07:58 AM in reply to: serverbrb
I think you'll benifit most from a new I-3 with about 8 gigs of ram & Win 7 64 pro as the most cost efficient way to get the  best performance from that version of acad.  Make sure the MoBo supports SATA 6 & get a medium sized HD spinning at 7600+.  I don't think a SSD is cost effective right now, unless it's hooked into a laptop.  I put money into a Velociraptor from Western Digital - fast & stable.
You don't need more than what a new I-3 can do with the older acad.  It's fast & the data throughput is better than anything else on the market right now for the price.  You might need to explore the installation proceedure for acad 2000 & win 7 64 bit, but it's doable.
I'd look at a Nvida graphics card that supports 2 monitors and has about 500 meg of Vram - nothing fancy or screaming, since there's not a lot of rendering to be done with acad 2000.
Reid
Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
*Expert Elite*
pendean
Message 7 of 7 (124 Views)
10-14-2011 11:49 AM in reply to: serverbrb
Processor speed, rather than number of cores, is more of an advantage for older software if the intent is "speed": as noted above, AutoCAD 2000 is a light weight, anything current from a office supply store is going to be fast compared to an older PC.
Just realize the limitations of AutoCAD 2000's abilities will not disappear with a faster PC: it's still slow at rendering, it's still slow at complex 3D objects, and 2D speed gains will be measured in nano-seconds and nothing more.
Don't overspend or over think the hardware needs for such an old software package.
You are not logged in.
Announcements
Need installation help?
Ask the Community
