No, the 2 GB isn't necessary today, but what about a year from now? I feel
much more comfortable buying all of the memory at once rather than adding
later.
I agree on the dual processors as to any one program. There might be an
advantage to have two if I were running two intensive programs at once.
However, I wouldn't go the extra 1200 bucks for the second one, although I
could have dropped back to 2.4 gig and got dual procs for another 200
bucks.
"Jon Rizzo" wrote in message
news:718C77135C511DD0BEBD930C331E4EC6@in.WebX.maYIadrTaRb...
> Is 2 GB really necessary for a home rig? I had a hard time convincing
> myself that the 1 GB I just bought was not overkill...
> in a home rig, you would get very little use out of the dual processor
> rig...the proof is in the lackluster gains that hyperthreading is showing
> (unless you look at benchmarks performed by Intel themselves, of
course...)
> "David Doane" wrote in message
> news:1D377C0D658B00D27F2A7DE379E5B21A@in.WebX.maYIadrTaRb...
> > Well, I finally decided to upgrade a bit. The old PIII-600 w/Win98 was
> > getting a mite sluggish, and Betty's machine was beating the pants off
me.
> > I started to build another one, but since I'm a bit behind the times I
> > decided to just buy one - a Dell Precision 650.
> > I could have used dual 2.4G processors instead of the 2.8G for another
> > couple hundred bucks, but made the decision to go this way. If I ever
> have
> > a reason for the dual processors I can always add another I suppose.
> > Intel® XeonT Processor, 2.80GHz, 533 FSB, 512K L2 Cache
> > E7505 Chipset with 533MHz FSB
> > 2GB Dual Channel, ECC, DDR266MHz SDRAM Memory (4 DIMMS)
> > Integrated ATA/100 EIDE controller
> > Integrated U320 SCSI controller featuring high-performance RAID 0
> > nVidia, Quadro4 900XGL, 128MB, VGA/DVI (dual monitor capable)
> > 80GB ATA-100 IDE, 1 inch (7200 rpm)
> > ??X CD-RW
> > 16X DVD-ROM and 48X/24X/48X CD-RW with Decode Solution, PWS
> > Enhanced Performance Keyboard, USB (8 Hot Keys)
> > Logitech, 2 button OPTICAL Mouse w/scroll, USB
> > 56K, v.92 data/fax modem, PCI
> > HarmonKardon, HK395, High-End Speakers, 2.0, w/subwoofer
> > Microsoft® Windows® XP Professional, SP1, using NTFS
> > Hyper-Threading feature set to "ON."
> > I already have two 21" monitors to use with this rig. The nVidia card
> > lacks many features that the Matrox cards have that I've been using,
> > though.
> > Oh, yeah. This thing has a 460W power supply *under* the computer,
with
> > two fans. It also has two processor fans in the rear and a card fan in
> the
> > front. It has an 8X AGP slot, 2-32-bit 33MHz slots, and 3-64-bit
100MHz
> > slots. For ports it has the usual keyboard and mouse, a 10/100/1000
NIC,
> 1
> > par, 2 ser, 6 USB 2.0 (2 front & 4 rear) 2 IEEE 1394a (1 front & 1
rear),
> > and the 3 rear audio ports plus a mic and earphone ports on the front.
> > The case doesn't *come* apart - it *swings* apart with the drives
mounted
> > in the door. Too bad they didn't make the cables long enough to open
the
> > door fully without unplugging something. Also, they connected both CD
> > drives to one channel and both HD's to the other channel. Looks like I
> > need to replace some cables. I'm gonna miss the SCSI drives, too. I
> could
> > boot from either drive with the old one.
> > Unaware that this thing included two CD drives, I also ordered a Sony
> > DRU-500a (on backorder). I think I'll cancel it though as I don't
> > currently have anything that will use DVD. Of course $305 wasn't a bad
> > price for it.
> > One last note: BeLarc Advisor ain't so smart. It says I have two
> > processors installed. Perhaps it sensed the hyperthreading.
> > Since the only thing I use it for beyond the usual stuff is plain
vanilla
> > AutoCAD, it should make a good "home" system, don't you think?
> > Dave D (drop the dash to reply)
> > May you always find Peace, Love, and Happiness in all that you do!
