• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Hardware
    Member
    64 bit Autocad on an Athlon 64 cpu on a windows XP (32 bit version?) ?
    118 Views, 6 Replies
    11-04-2011 05:25 AM
     I'm running standard windows XP SP3 on my Asus motherboard which has an Athlon 64 processor.
     I can buy a second hand copy of Autocad 2010 64 bit pretty cheap. Will it run on my machine? Or do I need a 64 bit OS first?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: 64 bit Autocad on an Athlon 64 cpu on a windows XP (32 bit version?) ?
    11-04-2011 06:09 AM in reply to: abrogard
    No, 64bit will not install on 32bit OS, and vice-versa.
    AND.... AutoCAD is not sold in only 32bit or 64bit, you get both free and at the same time if your source is legit: sounds like you are going to lose your shirt, enjoy those savings for 30days.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    *Expert Elite*
    DarrenP
    11-04-2011 07:16 AM in reply to: pendean
    its probably not a legal copy
    *Expert Elite*
    TravisNave
    11-04-2011 01:31 PM in reply to: abrogard
    Agreed.  You cannot buy a "second hand" copy because the license is non-transferrable.  You will be left with a trial version that will expire and never activate.  Only buy from certified Value-Added Resellers.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    11-05-2011 03:41 AM in reply to: abrogard
     Oh, okay, thanks for all that.  It is supposed to be from a deceased estate - the widow doesn't want any of this stuff. You mean I wouldn't be able to activate it if I got it because I'm a different person or because I've got a different machine - with that stuff about licence not transferable?
     There's no pressure. I don't need it. I use - no, I don't use - I have the 2008 version and I've never learned to use it.
    Valued Mentor
    11-05-2011 04:34 PM in reply to: abrogard
    Well, sorta.
    The lisencse is transferable......under certain circumstances, and for a fee.  In my case, the boss closed the office, and working through our reseller (Delta Engineering) we were able to transfer the lisencse into my name for $350.  It has to do with a transfer of assets if a company divests or splits.  I, then have become responsible for maintaining the subscription.  In the case of a death, I'm not sure the survivors can transfer the lisencse.
    For the other part of your question, you'll need to have a 64 bit OS before a 64 bit version of acad will work.  So, your choices are XP 64 (NOT recommended at all) Vista 64 (not really that good a choice), and Win 7 64 (not a home version) as the currrent supported OS.  If you're still running XP, it's time to do this anyway.
    Reid
    Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
    Member
    11-06-2011 01:36 AM in reply to: OMCUSNR
    Not worth my while bothering, is it? what they're selling me they can't sell... it's worthless to me...
    The lady will be interested to hear all this.  Sadder but wiser, she'll be.
    :smileyhappy:
