Insight Energy Forum
Welcome to Autodesk’s Insight Energy Forums. Share your knowledge, ask questions, and explore popular Insight Energy topics.
There is too much floor and ceiling area in the gbXML file
5 REPLIES 5
chengyuw
1723 Views, 5 Replies
I try to upload my gbXML file on green building studio, there is a error message
Invalid gbXML file: There is too much floor and ceiling area in the gbXML file received by Green Building Studio:   Floor and ceiling area = 315 m2Building area = 246 m2The floor and ceiling area must be within 20% of the building area to perform meaningful energy analysis.
I check my model and everything seems fine, I attached my model
5 REPLIES 5
ytun054
in reply to: chengyuw
I have the same problem and I posted a question but haven't got an answer yet. Have you figured it out ?
Same error here...does anyone has a solution
The 2014 version of Revit addressed this issue. What version of Revit are you working with?
Marjorie Stein
QA Analyst
Generative Design Group
insight.support@autodesk.com
chadwitk
in reply to: mstein7484
having the same exact problem with revit 2014
Mohammad_Asl
in reply to: chadwitk
Can you attach your model or send your gbXML file to this email address: bpa.tam@autodesk.com (I could not find your model attached to the first post).
Did you use Revit to create gbXML file? Can you send your Revit model as well?
Mohammad Asl
High Performance Building Design Researcher
Insight360.support@autodesk.com
