Green Building Studio
Active Member
duygualb
Message 1 of 4 (288 Views)
Accepted Solution
How to set thermostat temperature in gbXML file
288 Views, 3 Replies
03-26-2014 12:27 PM
Hi.
I was wondering whether we can set thermostat temperature in gbXML or in Revit. I have modeled a single family house in Revit and run building performance analysis in GBS. However, it basically assigns default values which includes thermostat temperature. I just wanted to change the range of the thermostat temperature and run it again. I would be grateful if someone could help me about it.
Thanks in advance!
Employee
mohammad.asl
Message 2 of 4 (275 Views)
Re: How to set thermostat temperature in gbXML file
03-27-2014 08:18 AM in reply to: duygualb
You can change the DesignHeatT and DesignCoolT under Zone node in the gbXML file.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Mohammad Asl
Building Performance Analyst (Intern)
Autodesk, Inc.
bpa.team@autodesk.com
Active Member
duygualb
Message 3 of 4 (268 Views)
03-27-2014 03:47 PM in reply to: mohammad.asl
Hi.
Thanks for the comment!
I have tried to change DesignHeatT and DesignCoolT in the gbXML file. However the results sound weird! I have attached the excel sheet including the results. I have a base case which has the default temperature set point (70 to 74) and I have set them 60 for heating and 80 for cooling.
Thank you so much!
Employee
mohammad.asl
Message 4 of 4 (252 Views)
04-01-2014 04:56 PM in reply to: duygualb
I think I misunderstood your question. DesignHeatT and DesignCoolT that I suggeted can be used for system sizing.
In order to change the zone temperature setpoints, you need to change heatSchedIdRef & coolSchedIdRef reference within zones. You will need to go to these schedules and edit the hourly temperature values for a 24-hour period. There may be several different day schedules, i.e. one for weekday, one for Saturday, and one for Sunday.
In the cases of schools building types you will get into seasonal schedules as well and not just one schedule for the entire year.
Mohammad Asl
Autodesk, Inc.
You are not logged in.
Announcements
Ask the Community
