Green Building Studio
Distinguished Contributor
bcpratt
Message 1 of 4 (2,020 Views)
HVAC Equipment
2020 Views, 3 Replies
07-09-2010 06:16 PM
The list of HVAC equipment looks extensive initially, but seems lacking upon further review.  I didn't see anything that would model a ground source heat pump.  Am I missing something?
Employee
mstein7484
Message 2 of 4 (2,012 Views)
Re: HVAC Equipment
07-13-2010 04:29 PM in reply to: bcpratt
We are in the process of adding more HVAC systems to the tool.  But please keep in mind that the main purpose of using Green Building Studio is for the conceptual phase, when details about your project are as yet undecided. We encourage you to use Green Building Studio to first determine the optimal footprint, orientation, opening size & placement, etc. for minimal energy usage (accounting for solar radiation control, daylighting potential, natural ventilation potential, etc.). Only once these major decisions have been optimized for energy efficiency should you worry about specifics of HVAC systems, etc.
Best Regards,
Marjorie Stein
Product Manager, Sustainable Design
Autodesk, Inc
Marjorie Stein
QA Analyst
Autodesk, Inc.
bpa.team@autodesk.com
Member
jwmsmith
Message 3 of 4 (1,477 Views)
Re: HVAC Equipment
06-19-2012 12:57 PM in reply to: mstein7484
I still can't finf a ground source heat pump option - has it been added?  If so, what is it called?
Employee
mstein7484
Message 4 of 4 (1,475 Views)
Re: HVAC Equipment
06-19-2012 03:33 PM in reply to: bcpratt
Because of the complexities in modeling heat pumps, we are still working on valid default assumptions to use for the simulation models. The workaround would be to download the DOE-2 input file from your initial Green Building Studio run, import this into eQUEST, and configure eQUEST to model a heat pump.
Kind Regards,
Marjorie
Marjorie Stein
QA Analyst
Autodesk, Inc.
You are not logged in.
Announcements
Ask the Community
