after "export Archive" of an object on your computer. What is the best method to import the item into another project?
Fabio
Hi Fabio.
If you are looking to import an item into a project, what you can do is use the "Import CAD data from local hard drive" command on the dashboard, and define the project as the one you are looking for. This will import the local archive that you exported into the project you specified.
What I think your question is asking is how do you import a design into another design. This can be done using the insert command under the assemble tab inside of your target design. The insert command will search your existing designs across all your projects and you can choose from that list.
I hope this answers your question,
That's what I had done, but the answer is "importing timeline design in to direct design is not supported yet"
Fabio
With a new open design the answer is:circular dependencing found
If I import the file. Iges I have no problems
Fabio
I do not know why, inexplicably, the file is now visible and I can open it.
It's a mystery ... sorry for the trouble!
Ciao
Fabio
Hi Fabio,
Glad to hear things are working correctly for you now. As always any issues please keep letting us know.
Cheers,
Hi Joel,
After reviewing the answer to Fabio question on re-importing a f3d file into another project, the assembly tab in my version does not list an Insert command. Is there a different solution? I'm working in the student version. There is no way to export to an appropriate file such as svg or dxf file formats in order to import under the Insert tab. Only SAT, STEP, SMT, and F3D and none that can be imported via the Insert Tab.
Any recommendations?
This is an old thread so thing might have changed. You can open a locally stored f3d using New Design From file on the file menu. Then save to a project after saving you can use Insert into Current Design. Or you can upload directly using the data panel, using the cloud icon.
Mark
Mark Hughes
Owner, Hughes Tooling
Another option, if you have the full path and filename to the file is use the HTML file in this thread, it will allow opening and inserting locally stored files.
Mark
Mark Hughes
If you're still struggling post some screen grabs of what you're seeing.
Mark
Mark Hughes
