With the latest version, I'm unable to create a 2nd box in a model by specifying numerical inputs. Steps to reproduce:
1. Create a box.
2. Create a 2nd box, starting on one corner of the first box. Don't use the mouse to draw the initial rectangle, just use the mouse to select the firrst point, then use the numeric inputs.
3. Type a length in, then a width. Click return twice, which used to bring up the dialogue to enter the height.
Expected results: Dialog comes up, and you can enter the height.
Actual results: Get the error "Sketch geometry is over constrained."
The work-around is to draw the initial rectangle with this mouse, which is imprecise, but then a dialogue will come up allowing you to enter all 3 dimensions, which works.
Also, when entering the dims using step 3 above, it will always lose the first key input on the 2nd dim. I.e., if I try to enter "3" return, then "14", I'll wind up with "3" and "4" instead.
Thanks for posting about this problem
Unfortunately we were not able to reproduce the error "Sketch geometry is over constrained." here, is it possible to attach a video about this?
About the input problem you mentioned on the end, I will transfer it to Product designer to take a look it.
Now, you can try to enter the value without pause, it should be work well. If you want to enter other value, you don't need to remove the old value and enter the new value directly. I hope you like the design.
Here's a video reproducing this issue:
Or you can go to this URL: https://vimeo.com/92069009
Rob
Thanks a lot, Rob!
It's a perfect video. I get the problem clearly now. I will report the case into the internal issue tracking system and ask the development team to look into it.
There is a workaround. You can try to use click to replace Press Enter when set the second sketch point. There is no error popping up.
