Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Why can I import dxf files, it always shows errors.
5 REPLIES 5
george
1819 Views, 5 Replies
When I import this file,it shows error,and can not import. But I try to read with 2D CAD ,it is OK, I can see the drawing.
5 REPLIES 5
innovatenate
in reply to: george
Hi George!
I'm not sure why this dxf is not working with the translator! Thanks for sharing this file. I will forward this to the development staff for further investigation. In the meanwhile, here is a copy of the file the I first routed it through AutoCAD, exploded, and then imported into Fusion 360. Let me know if this helps or if there is anything else I may help with.
Nathan Chandler
Principal Specialist
Macro.Liu_Autodesk
in reply to: george
The file has already been shared with the development team and we're working on it.
Macro Liu
Fusion QA Team
Hate to revive a bit of an older thread, but I'm having the same sort of issues. The file won't import and all Fusion 360 tells me is "There are some errors."
It opened fine in Mastercam X7 HLE.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
ShirleyShi
in reply to: Steinwerks
Hi atomkinder67,
Thanks for reporting this issue to us. I think we found the reason: your file has a locked layer while Fusion doens't handle it well for now. A workaround to this is: You can unlock the locked layer, save and try again in Fusion 360. I attached the file I unlocked the layer by AutoCAD and can open it in Fusion 360. We would like to fix this kind of issue later.
Thanks again for your input.
Shirley
Developer for Fusion Electronics
Autodesk, Inc.
ShirleyShi
in reply to: george
Actually it is partially fixed. Our developer is working on fixing the first issue for showing error(fle: Pcduino-Top.dxf, what we observed is many polylines are missing). and the second issue has a workaround and we will add the fix in next release.
Shirley
Autodesk, Inc.
