I am looking to change the spline display colour and thickness to allow me to constrast the spline against the colour of the image I am modelling. I currently reduce the capacity of the image to attempt to acheieve a better contrast, but it would be much better if I could change the spline colour/thickness 'on creation' not just the resulting spline 'after creation'.
Thanks for reaching out!
By 'I currently reduce the capacity of the image', I assume you've already tried to adjust the Opacity of the image. Have a try if you didn't.
Currently setting the color/thickness of sketch geometries is not supported. Another possible workaround (besize the above) is to choose the most suitable Environment:
Also, if the shape of the spline matches your expectation, you can Fix the spline since the fixed geometry will be 'Green':
Hope this helps.
Macro Liu
Fusion QA
BTW, you can also post a new request to the Idea Station: http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/idb-p/125.
Macro Liu
Thanks for ideas, yes I meant 'opacity' not 'capacity'. The challenge is I am sketching splines on a black and white image so it is difficult to see the spline creation line until after it is created and turned green. If it is not possible to change spline creation colour I suppose an alternative could be to inverse the colours on the image to constrast with the spline creation colour.
