There seems to be a problem with toggling between these functions, keep clicking on model and nothing happens
It sounds like you are trying to change from the Sculpt to the Model work space, but the ribbon is not updating when selecting the Model icon in drop down on the far left of the ribbon. Any idea when this stopped working? Does this issue persist after restarting Fusion 360?
its been dodgy since the last update, it does work but maybe after ten attempts
So far I haven't been able to witness this first-hand. Is there anything failry unique about your "set-up" (i.e. dual monitors, old graphics card, old graphic card driver, Large Text settings)?
Is this occuring on a Mac or a PC? If you're on a PC, have you updated the display driver recently?
In Windows, I've seend the Custom Text Size (DPI) setting in Control Panel\All Control Panel Items\Display effect the ribbon and view cube performance before. I would recommend using "100%" as the setting if this applies to you.
Keep me posted!
Dean,
Is it possible for you to create a video of this behavior? Jing is a free application that will let you take screen captures for up to 5 minutes. This will give us more information.
I am with Nathan and have not experienced this behavior.
Andy
