Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Position a ring on the finger
2 REPLIES 2
Dan_Margulius
311 Views, 2 Replies
I am trying to create something I so on your site:
https://www.youtube.com/watch?v=HKryzEk7jA4
I imported the hand in Fusion but I have no idea how to move the T pline body to the finger.
How can it be done?
Dan
2 REPLIES 2
keqingsong
in reply to: Dan_Margulius
Hello Dan,
Thanks for reaching out. To move a sculpt body or any bodies in Fusion 360, you can approach it a couple of ways.
First way:
Find the body in the browser > right click > select move
Then use the various manipulators to move the body to where you want it to be.
Second way:
Double click on a surface of the body to select the entire body > right click > select Edit Form
Since the entire body is selected, use the manipulators to move the body to where you want it to be.
Tip: If you click and drag the center manipulator, it will global scale the model, not global move it.
Does this help?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Dan_Margulius
in reply to: keqingsong
Hello Keqing,
Thank you for the help.
I did something, looks fine.
