I am trying to create something I so on your site:
https://www.youtube.com/watch?v=HKryzEk7jA4
I imported the hand in Fusion but I have no idea how to move the T pline body to the finger.
How can it be done?
Dan
Solved by keqingsong. Go to Solution.
Hello Dan,
Thanks for reaching out. To move a sculpt body or any bodies in Fusion 360, you can approach it a couple of ways.
First way:
Find the body in the browser > right click > select move
Then use the various manipulators to move the body to where you want it to be.
Second way:
Double click on a surface of the body to select the entire body > right click > select Edit Form
Since the entire body is selected, use the manipulators to move the body to where you want it to be.
Tip: If you click and drag the center manipulator, it will global scale the model, not global move it.
Does this help?
