Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Perforations how to?
2 REPLIES 2
annaromanovska
1756 Views, 2 Replies
Hello all. I'm trying to add perforations and the best way I thought of so far is to create a small body and pattern it around the path, then subtract those bodies from the larger one. However it's time consuming and cumbersome. Is there a better way to do this?
Anna
Tags (1)
2 REPLIES 2
A good suggestion may be to pattern a feature using the 'along a path' option. In this scenario, you would create one extrude cut feature and a sketch to represent the path of the perforation, and then use the Model > Create > Pattern along path feature to copy this extrude cute feature along a the sketch path. Please note that the path may need to be continuous and tangent, so you may have to add small fillets at any sharp corners. This may or may not be necessary.
Please let me know if this helps or if you have any other questions.
Nathan Chandler
Principal Specialist
Phil.E
in reply to: annaromanovska
As Nathan says, Pattern on Path will work for extrude-cut or holes. There is a critical setting that gives this command a lot of flexibility: Orientation.
Identical
Path Direction
Also you may find the need, especially for non planar paths, to move the path origin closer to the feature being patterned (by dragging it).
Let us know if this helps!
HP EliteBook 8560w Win 7
13" MacBook Pro, mid 2009 OS X 10.8.4
Portland, Oregon
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
