Hi, are these functions going to be added to the Parametric Mode in future updates? Now we have to go to DM mode in order to make copy/paste of Components Independent. Mirror as well. I like the Parametric mode but these functions are welcomed.
Thanks.
Solved by Macro.Liu_Autodesk. Go to Solution.
OK Mirror fucntion is available at the "Create Base Feature" command. The "Paste New" and "Make Independent" for Components are the ones that should be added to Parametric Mode.
Right now at Parametric Mode in order to make the Copy independent I have to combine the bodies in the component.
We have tracked these issues, which the development team is working on. Thanks a lot for sharing the feedback with us!
Macro Liu
Fusion QA
I have derived a work flow to solve this problem until a fix could be updated. It is my reply to the following subject: http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Independent-copy-in-history-mode/td-p/4938050
I also have derived a work flow to solve the temporary "Scale" problem in the Parametric Mode. This is the link: http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Temp-Work-Flow-for-quot-Scale-quot-and-quot-C...
Hope this will help!
