The current build of Fusion360 does not have the ability to "draw" an equation controlled parabola. Here are 2 suggestions.
1) Try modeling a cone and inserting a plane if you know the angle and starting position WRT the base of the cone. You can then project the intersecting edges of the cone into a sketch created on the plane and get a parabola.
2) If you do not need the parabola to be precise (you are just going for close enough) you could use a spline curve with symmetry.
Give that a try and see if this gets you to your solution. If you are having problems with this let me know and I will help you work on it. Might need to break out that geometry or calculus book. 🙂
Andy
hi
for complex geometric funcions I usually use the Maple, but this has also plots SVG (http://www.padowan.dk), and plot the SVG can be imported to Fusion 360
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
I am going to take a screenshot of a parabola in desmos and then trace the screenshot with a bunch of little curves... wish me luck
i have just created a parabola with the control point spline function. its seems to be exactly what i needed.
I hope the image shows the relations clear enough, since i dont know how to explain it clearly.
i've made a screenshot of a parabola that i made in geogebra, and used that to trace it and it seems to be exactly following that function. (y= sqrt(18.906x) A(9.543,0) )
There are two ways in Fusion 360: Conic Curve with rho=0.5, and Control Point Spline. Locate three points before drawing the curve:
- the two endpoints of the parabola
- the point where the tangents to the parabola endpoints intersect
For more detail, please see my reply to a similar question:
Another way if you know the Parabola function you are using make a table and solve for the values and put those points in then connect it with a spline, mirror it about the vertex and it should make the parabola pretty nice. Just like we did back in Algebra 2 in High School.
