We have released an update to Fusion 360 to address a few quality issues that were reported by you (our customers). Below are the issues addressed by this update.
1. Instability with Save Copy As and Save As STL
2. IGES export not being read in correctly in other products such as Rhino
3. Unable to enter decimal values in the heads-up-display
4. Variable radius fillet failing in Parametric mode
5. Browser cross highlighting broken
6. Workplane projection in sketch does not update
7. Couple of other crashes reported
We hope this gets you back on track and sincerely apologize for the incovenience caused by the previous update. Please do let us know what you think of the update and keep giving us your feedback. We are listening and want to do the best we can for you.
best regards,
Sanjay Jayabal (Autodesk)
On behalf of the entire Fusion 360 Team.
Hi Nicolas, Thanks for believing in me. That is actually good news. I was trying to reproduce some crashes and I am glad that your team can do that too. Awaiting for the next update, then I will test it again.
Thanks for your help!
Kingson
Hi Nicolas, Jake sent me a video link to Garin's tutorial on the Parametric Mode. I think it is a great video. It actually shows us more about the use of the Parametric Mode. In fact I really like the mode. I will avoid the things I did to get the crashes like dragging the mouse slower on push pull and plugging in numbers instead of pull on small objects. I will continue to use it. If fact i will save to a new version the next time i have to move an offset plane, which requires to stop recording completely. Well I hope this move command on offset plane can be implemented in your next update. Those crashes in my report can be avoided in fact. If i know how to create them I know how to avoid them right? Well i will make a new pendant desgin in Parametric Mode to day for our own shop, that I can afford to have frozen program because it is not my client's. My own design is OK!
Thanks.
Thanks for the feedback, Kingson.
Yes, Garin’s video shows the key benefits of the Parametric Mode & how direct and parametric coexist nicely together. We’d like to hear more customer feedback to make this mode better.
Looking forward to your voices.
Thanks for the feedback about making update notes more obvious - this is something Keqing and I have been talking about. I love the way Evernote does this. What would you guys think of something like this?
regarding parametric modelling I still want to have some information which tools will work in parametric modelling and which not.
So all tools should appear in the toolbars all the time independent from modelling mode.
If I am in or switch to parametric modelling the tools which do not work right now should be disabled, greyed out.
A yellow hint on hovering the mouse over a disabled tool should say 'This tool is only available in direct modelling mode'.
This would make things more clear.
You can yourself read many threads here where users (inlcuding myself) ask 'Where had this tool gone?'.
So please make all the tools visible all time and give the user clear feedback by just disabling them in parametric modeliing mode and showing a small hint.
Thanks a lot!
