Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to move an edge
8 REPLIES 8
Message 1 of 9
13209 Views, 8 Replies
How to move an edge
Ok I have a box and wouuld like to move one edge down so I create a taper, but how?
I try clicking a line the click move and the whole box moves
8 REPLIES 8
Message 2 of 9
innovatenate
From the Modify drop down in the Model work space, you can use the Edit Face command to accomplish this. Please review the below video and let me know if it helps!
http://screencast.com/t/w0B76QbjJQ
Nathan Chandler
Principal Specialist
Message 3 of 9
rishivadher
hi go to "SCULPT" mode, "MODIFIY" and "EDIT FORM" from the "Selection Filter" select the Edge.
Message 4 of 9
Phil.E
If you have a Model box, right click on the face and use Move. A manipulator allows you to rotate the face and thus create a taper.
HP EliteBook 8560w Win 7
13" MacBook Pro, mid 2009 OS X 10.8.4
Portland, Oregon
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 9
in reply to: Phil.E
i'm trying to move the part with all the fillets so that part goes down to 15mm from 30mm and tapers the long part down....hope that makes sense
Message 6 of 9
Phil.E
Okay, the picture really helps.
The Move command is a good choice here. Move is dependent on selection. So start by selecting the faces on top of the shape you need to taper.
Next, right click and pick Move. You will need to reorient the manipulator.
Then rotate the surface around the new base point of the manipulator.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 9
SGoldthwaite
in reply to: Phil.E
I'm trying to tilt one of my faces, but when I use the Move tool and try to select just the face, it keeps selecting the whole body.  Here's my design
http://a360.co/1CS3KbB
Message 8 of 9
Phil.E
in reply to: SGoldthwaite
The tools and workflows shown above are only available in Direct Modeling, or DM, or "history free". When this post was originally made, Fusion had no history or parameters. Check out the pictures, there is no timeline.
Currently, to work this way you can do one of three things.
1. From a parametric design with a timeline (default workspace), you can pick Base Feature. This creates a "history free" (DM) feature in your timeline. It could be any kind of modeling you want to do without any parameters, including move face.
* Caution: you can only use DM tools on bodies you create while working in any one particular Base Feature. You cannot modify parametric bodies.
2. From a parametric design, turn off history. Use the Gear icon, lower left by the end of timeline, and pick "Do not capture design history".
* Caution: you will lose all of your model history when you do this. If you turn history back "ON" you do not retrieve your old history, only create new.
3. Start new designs as DM by turning off history in Preferences as your default modeling mode. While you are there, check out the other preferences you can set!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
Phil.E
in reply to: Phil.E
Sorry, forgot to answer your main question:
Use the draft command to tilt faces in Parametric Modeling.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
