ADF360 Forum,
After I modify or ammend a sketch used to generate a solid, how do I execute a global update or refresh so that the model reflects the changes?
Thank you,
CPEProjE
Solved by garin. Go to Solution.
At the moment Fusion 360 is a direct modeler that doesn't capture history or parametrics. That means once you extrude, revolve or loft something from a sketch, the feature wont update if the sketch is edited. To edit your design you can use Press Pull to make changes to your model.
That said we are madly working away at adding parametrics to Fusion 360 in an update slated for mid to end of December. This will allow you to create sketches with equations and dims that when edited will update downstream features. Many people still really like direct modeling for quick concept models so we wont take that away, just add a way to build parametric models also.
If you are interested in getting your hands on it a little early to give us feedback, shoot me a direct message with your email address and we will try to get you an early preview of it.
Hip, hip hurray!
"create sketches with equations and dims that when edited will update downstream features"
Hugs to the development team!
