Is there a way to save one model that is currently using t-splines to a usb drive or even email it to another autodesk profile? The story is I started one model on a work ID and want to keep working on it at home under my own autodesk id. How do you do that? I tried saving the archive to a USB drive but when I opened it under my other autodesk ID there was nothing there.
Ideally you could just use one id to for work and home use. If for any constraints you want to keep separate ids you could invite one (home id) to your group the work id's design is part of. If that too is not desirable you could create a new group with the 2 ids and export your design to this new group.
Not sure why your archive didn't open. Can you upload it or send it to me at anandDOTkaryekarATautodeskDOTcom?
Anand Karyekar
Fusion360 Development
