Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to add parts to an assembly?
3 REPLIES 3
693 Views, 3 Replies
lets imagine that I have make two drawng in seperate files. How do I add them both into a drawing and make an assembly?
This must be very simple, but I find no way of doing it!
thanks.
Tags (1)
3 REPLIES 3
Oceanconcepts
It is simple, but not very intuitive or obvious.  There is a little magnifying glass icon at the upper right of the window.
search icon
If you click on it it will expand to a search box.  You can type the beginning of the file name you want to add, it will search in the project and come up with a list- select the one you want and it will be placed in the drawing with a move tool active.
Unfortunately you don't seem able to browse- you need to have an idea of what the file name is.  And the process is hidden behind a non-obvious icon, rather than identified with text or a menu item. Easy, once you know how to find it.
- Ron
Mostly Mac- currently M1 MacBook Pro
in reply to: Oceanconcepts
Thank!
Yes its quite obscure!
I was expecting that there was a hidden "place" menu item somewhere...
garin
We have a new dashboard we are working on and will make this workflow much easier once we roll it out. This is a very comon question and I agree not discoverable at all.
