So every time I try to open Fusion 360 or Fusion Simulus an error occurs and a Fusion 360 Error Report pops up. I can't even start the program. Any help would be highly appreciated.
error report CER_77781765
Let me look into this issue with this error code and see if we can determine what might be happening. Are you using Windows or OSX? What version?
I am sorry to hear you are having problems with Fusion 360. Please try the following and see if it helps.
Please let us know if this resolves the issue.
You can proceed to step 5. Make sure that you complete steps 3 and 4 right before step 5. If you have closed the Terminal window, you will need to execute the commands again. Step 5 removes some files so it is important that it is removing them from the correct location.
Have you ever successfully invoked Fusion 360 ?
Great, let me know if completing step 5 above fixes the problem. If it doesn't, I have one other thing for you to try.
Neither of these solutions work...
The only thing that shows up is the Autodesk Fusion that I already had on this Mac before I downloaded Fusion 360.
If deleting the files in $TMPDIR\Autodesk (outlined above) did not work, please try the following.
If this does not work, you can try to reinstall the application.
Unfortunately, that didn't work either. Is there a way I can uninstall all Autodesk programs and start over?
I am sorry that did not work. You can uninstall the application by right clicking on the Fusion 360 launch icon in the dock and selecting Options > Show In Finder. When the Finder window opens, select all of the files/directories and delete them (Move to trash).
You should have recieved an email providing a link to our new S3 release. You should install the latest version. If you still have problems or these directions are not clear, reply to this thread and I will help you.
I did not receive the email, but I did try reinstalling the version I received less than a week ago. No dice. Still won't load. It just keeps going to submit error report without loading. If the S3 version is newer than the one I received, would you please send that link to me? If that is the version I already have, I will just continue designing with the regular Fusion on my system. Thank you for all your help.
-JH
I have sent you a private message with the link. I believe this will fix the issue. Please let me know if this helps.
when i open fusion after installing this massege is show
you must log in to run this application. do you want to exit the application
plzzz hellp
Have you ever been able to run Fusion 360? Did you get your version of Fusion from http://fusion360.autodesk.com? If not, can you uninstall and re-install from this website? Let me know, if after you reinstall, you can not run the software.
This post might also help you with this issue:
http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Can-t-open-Fusion-360/m-p/4488497
Are you still seeing this error during the installation?
If yes, please try to remove the “webdeploy” folder ,then install the Fusion again.
For the details of how to do a clear un-installation, please go to http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/Fusion-360-Known-Issues/td-p/4311780 [bottom of the page].
If the error dialog is still there, please help take a screenshot of it (better if it contains the detailed error message) and share with us. This would be really helpful and we'll continue to work on it.
Thank you very much!
Macro Liu
Fusion QA Team
