Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion 360 unresponsive...
2 REPLIES 2
whunter
678 Views, 2 Replies
...if one is logged on for a long period but not using the app. I started a new design yesterday, but didn't log off from F360. When I returned today (>24 hrs later) I was greeted with the following message:
xoauth_problem=parameter_absent&xoauth_parameters_absent=oauth_token&oauth_error_message=Missing+parameter%3aoauth_token
F360 was unresponsive, had to kill the app.
Win 7 64-bit, South Africa.
Please mark this as Solved if it answered your question, other people may find it useful too.
2 REPLIES 2
innovatenate
in reply to: whunter
Are you behind a proxy server? Did the machine hibernate or go to sleep while you were away? Did restarting Fusion 360 resolve the error message?
Nathan Chandler
Principal Specialist
whunter
in reply to: innovatenate
Not behind a proxy.
Yes, the machine either hibernated or went to sleep.
Yes, restarting Fusion solved the problem.
