Discussion Groups
Get Help with Fusion 360
Member
Fusion 360 install problem
420 Views, 10 Replies
06-26-2013 12:24 PM
Please use plain text.
Re: Fusion 360 install problem
06-26-2013 12:53 PM in reply to: kaed.sisler
Yup - I got the same.. Repaired permissions on disk.. Figured that would fix this, but seems not..
Al
philip.s
06-26-2013 02:06 PM in reply to: alistardean
We're looking into potential causes for this error and will get back to the both of you ASAP. Apologies for the inconvenience and thanks for your patience!
Philip Schmelzer
Product Support
innovatenate
06-26-2013 02:35 PM in reply to: kaed.sisler
Would it be possible to attach the log file mentioned in the warning?
Also, can you make sure that you've uninstalled the beta per the instruction in the below post.
http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/How-to-uninstall-beta-and-export-designs-whil...
Nathan Chandler
Member
06-26-2013 03:38 PM in reply to: kaed.sisler
Log file mentioned in the warning.
Product Support
innovatenate
06-26-2013 04:55 PM in reply to: kaed.sisler
Thanks for posting the log file. While we are investigating the log file, can you confirm whether you were able to successfully delete any older webdeply folders prior to starting the re-install process? See the below post for details on this process.
If you have successfully removed the old beta version, can you re-try to download the installer from the community hub.
http://fusion360.autodesk.com/
Thanks for your patience, please keep us posted on your progress!
Nathan Chandler
Member
06-26-2013 05:17 PM in reply to: innovatenate
I did do what you asked before I posted on this site. With that said, doing so did not fix the issue.
06-27-2013 01:13 AM in reply to: kaed.sisler
Here's a new one.. Error notification and log file attached Screen Shot 2013-06-27 at 09.11.20.png
06-27-2013 06:13 AM in reply to: alistardean
For anyone that comes up against Permissions, particularly relating to the Home and Applications folder in OSX, repairing them with Disk Utility doesn't work.
Best fix is
Reboot with Command + R
That'll boot up the Utilities
From there, you can select Terminal from the pulldown menu
Type resetpassword (don't panic, you're not going to do that)
Then, at the bottom of that dialog, there's a button for Repairing Permissions. Hit that, wait for it to complete.
Then make sure that you've followed the uninstall options if you've run the beta, then install again..
Should work.
Al
philip.s
06-27-2013 09:31 AM in reply to: alistardean
Thanks for sharing this solution with the community Al!
Philip Schmelzer
