Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Exporting as DXF or DWG
2 REPLIES 2
thomasmccluskey
790 Views, 2 Replies
Prabakar, Thanks for your prompt reply. In the meantime, I'm having problems exporting my Fusion 360 models into dxf. or dwg. format? I'm getting an error message even when I try to open them up in their E Drawings format. Any idea what could be causing this problem? Thanks, Tom.
___
Moderator edit: Moved this question to "Help" so that others with a similar issue can reference it. Original thread here.
2 REPLIES 2
Tom,
Can you please provide us with screen shot of your error message.
Thank you.
Bob Holland
Autodesk Product Support
AndrewSears
in reply to: bob_holland
Tom,
I am getting errors trying to open exported .DXF files with DWG TrueView but the file will open.  The error seems to be on the viewer side.
Error:
"dwgviewr.pat"
Can't find file.
 Are you comfortable adding me to your group?  This will give me access to the files you are having issues with and I can test them on my machine.
If you don't want to add me to your group, please export and email the file to andrew.sears@autodesk.com.  IF you email them, please include the exported files along with the Fusion file.  I can send you a FTP link if the files are large.
Andy
