I tried importing a STEP model of a gas grill from Grab CAD, basically a prop to use in a rendering. http://grabcad.com/library/weber-grill/files/Grill.STEP
It imported into Fusion, and I eventually got a report saying some surfaces had been simplified.
I can open it and edit it. However, when I try to place it into an existing drawing, Fusion hangs up.
Ron
Ron,
You may want to try to delete and re-import it. I just test the grill.step file referenced, and it seems to work okay. The design I placed it into was a small one. Have you tested with any other designs to see if the issue is specific to one?
