Now for no particular reason, every time I start Fusion 360 it loads then crashes straight away. Have tried rebooting, uninstall/re-install, etc. It happens every single time. NO changes made to my computer.
Any ideas??? Please help.
Ben
Solved by capella_ben. Go to Solution.
Re-installed graphics driver (was on the latest version). Still crashes.
Ben
Did a full uninstall and re-install of graphics drivers. Still crashes.
Please help
Ben
Hi Ben,
I note in the reports that you're operating system has been updated to Windows 8.1. Can you verify in the Control Panel when this was installed? I am not sure if Fusion 360 is compatible with the 8.1 update; however, I will verify this and get back to you.
See the below image for reference on where to verify the update install date.
I upgraded to 8.1 then founf that inventor fusion no longer worked.
This was just after 8.1 came out. I'll check on the date when I get back to that computer.
Fusion 360 was working fine on 8.1 from then until now.
I had a look in the %appdata%/Autodesk folder and experimentede with renaming out various folders. Eventually I found a combination that worked. and now have it running. I guess it may have been some corruption in there somewhere.
Ben
