Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Bug in Dissolve Feature? Ghosts result in haunted drawing.
2 REPLIES 2
Oceanconcepts
1274 Views, 2 Replies
I'm trying to de-clutter the browser by using the Dissolve command on some of the long list of features, like Extrude 374, that I don't care about editing. This was a suggestion from AU.
But when I use this command, a "ghost" image of the body associated with the feature appears in the drawing, and I can't get rid of it.  It's still there even if I Undo the Dissolve command.  Even if I turn off visibility for everything in the drawing.
This behavior is consistent and reproduceable, and feels like a bug. I note that closing and re-opening the document seems to clear up the ghost images.
- Ron
Mostly Mac- currently M1 MacBook Pro
2 REPLIES 2
We have seen the same thing. This seems to be a reproducible bug and we will get the team on it. Thanks.
Kevin Schneider
schneik-adsk
in reply to: schneik-adsk
I can confirm a close and open will fix this for now.
Kevin Schneider
