I originally downloaded the Fusion 360 beta in August, and haven't had the time to play around with it since.
It appears that all the models I made back then (10 weeks to be exact) are now corrupted. I'm recieving the following message in the bottom corner of my screen whenever I try to open one up.
"The file you are trying to open or operate it corrupt! The current operation will be aborted."
I understand if this is simply due to the fact that Fusion is updating all the time, but it's just something I thought I should make y'all aware of for the time being.
Solved by thomasmccluskey. Go to Solution.
Hopefully we can get to the bottom of this one Tom!
Can you please invite me (philip.schmelzer@autodesk.com) to your group where these designs are hosted for troubleshooting purposes?
Tom,
Can you add me also? I can work with Philip to see what is going on.
andrew.sears@autodesk.com
Andy
The problem seems to be sorted now, whatever you two did worked. Thanks!
Happy to hear Tom!
