What is the best way for me to close this gap between my bearings component and my square tubing component?
I have attempted to move and snap them; however, I couldn't seem to get the center of the move widget on the edge of my cylinder.
I added a tangent construction plane to the bearing component. But when I tried the move and snap the plane moved not the bearing. I did have move component selected in the move helper window.
I attempted to use align several different ways, none of them seemed to work.
I have no tried using joints because ultimately the joint will be these bearing sliding up and down the tube.
What am I missing?
Thank you in advance,
Jeremy
This does bring up one of the areas we need to improve on the move/align commands.
One way to "close the gap" between the bearing and the tube is to turn on contact and drag the bearing over to the tube until it comes in contact and stops. You may want to add a slider joint between the dace flat face of the bearing and the outer face of the tube to keep it in collinear to the tubes face.
To turn on contact go to the Assemble drop town and "Enable Contact Sets" then in the browser Right Click on "Contact Sets" and select "New Contact Set". You can then select the two components (Bearing & Tube) that you want to touch one another. Select Ok and then drag the bearing over to the tube till it comes in contact.
Hope that helps a little.
Thank you for the reply; however, I did as you suggested with no joy.
Here is a screenshot of the contact set:
And here is a screenshot after moving the bearings:
Thank you again!
Jeremy
Jeremy,
Can you add me to your group so I can look at the file? Send the invite to andrew.sears@autodesk.com.
I am unable to reproduce the behavior you get. I downloaded the same McMaster Carr bearings you show in the model.
Andy
I added comments on your activity feed. You should have received an email notification and you should be able to find the feed. If you did not we should explore that next!!
I found the same strange behavior with your model. To remedy this, ground each tube. The behavior you were getting is coming from a result of the contact solver trying to move another component. This was causing long pauses and the interference you got. We have more work to do on handling contacts in Fusion. Thanks for pointing this out.
I grounded the tubes in your model and the contacts were working great and fast. Let me know if you are getting different behavior on your machine.
Andy
It is working great. Thank you! I'll remember to ground some component first.
As for the email notification when you posted a message to my group. I can see it in my dashboard; but did not recieve an email notification. Is this a setting someplace I may have turned off?
Thank you again,
Jeremy
My apologies but the software is changing so much that I sometimes loose track of what is implemented, removed, made up in my head, or coming into a future release. 🙂 I will check on the email notification at work tomorrow to see if we are still sending with changes to the activity feed and what the rules are. I know we are getting emails after translating a file into Fusion. This might be another area for improvement if replies are not coming to you.
Glad to know you saw the reply in the activity feed still.
Can you check if this box is checked?
Andy
