Hi everyone,
since there is no VRED Forum, I am using this one hoping someone can help me with my problem:
I just installed the new VRED 2015 Professional and everytime I am trying to open the material editor the programm crashes.
Here is the terminal:
Initializing OpenSG ...
OS Version 6.0 service pack 0.0
Loading Plugins ...
Loaded plugin 'vrKernelPreferences.dll'
Loaded plugin 'vrFade.dll'
Loaded plugin 'vrFrame.dll'
Loaded plugin 'vrInterpolator.dll'
Loaded plugin 'vrMenu.dll'
Loaded plugin 'vrMoviePlayer2.dll'
Loaded plugin 'vrParticle.dll'
Loaded plugin 'vrParticle2.dll'
Loaded plugin 'vrSwitch.dll'
Loaded plugin 'vrVideoGrab.dll'
Loaded plugin 'vrVirtualEye.dll'
Loaded plugin 'vrWater.dll'
Loaded plugin 'vrWebOverlay.dll'
Loaded plugin 'vrWidget.dll'
Loaded plugin 'vrCollision.dll'
Loaded plugin 'vrJoystick.dll'
Loaded plugin 'vrKey.dll'
Loaded plugin 'vrSpacemouse.dll'
Loaded plugin 'vrTimer.dll'
Loaded plugin 'vrTouchSensor.dll'
Loaded plugin 'vrViewPoint.dll'
Loaded plugin 'vr3DM.dll'
Loaded plugin 'vr3DS.dll'
Loaded plugin 'vrA3SLoader.dll'
Loaded plugin 'vrASCLoader.dll'
Loaded plugin 'vrBCAD.dll'
Loaded plugin 'vrC4d.dll'
Loaded plugin 'vrDWFLoader.dll'
Loaded plugin 'vrFhs.dll'
Loaded plugin 'vrMaya.dll'
Loaded plugin 'vrOsf.dll'
Loaded plugin 'vrPovRayWriter.dll'
Loaded plugin 'vrSLPLoader.dll'
Loaded plugin 'vrSTLLoader.dll'
Loaded plugin 'vrTSOLoader.dll'
Loaded plugin 'vrWRL.dll'
Loaded plugin 'vrAmbientOcclusion.dll'
Loaded plugin 'vrAnimation.dll'
Loaded plugin 'vrAnimationWidgets.dll'
Loaded plugin 'vrAnnotationModule.dll'
Loaded plugin 'vrAssetsModule.dll'
Loaded plugin 'vrCAD.dll'
Loaded plugin 'vrCameraEditor.dll'
Loaded plugin 'vrClippingModule.dll'
Loaded plugin 'vrCluster.dll'
Loaded plugin 'vrCubeImages.dll'
Loaded plugin 'vrGeometryEditor.dll'
Loaded plugin 'vrGridHelper.dll'
Loaded plugin 'vrInteractionModule.dll'
Loaded plugin 'vrLightEditor.dll'
Loaded plugin 'vrMaterialEditor.dll'
Loaded plugin 'vrMeasurementModule.dll'
Loaded plugin 'vrNodeEditor.dll'
Loaded plugin 'vrNotificationModule.dll'
Loaded plugin 'vrOpticoreStudio.dll'
Loaded plugin 'vrOptimize.dll'
Loaded plugin 'vrOptimizer.dll'
Loaded plugin 'vrPLMXMLModule.dll'
Loaded plugin 'vrPostprocessing.dll'
Loaded plugin 'vrRenderLayerModule.dll'
Loaded plugin 'vrRenderQueueModule.dll'
Loaded plugin 'vrRenderSettings.dll'
Loaded plugin 'vrRulerModule.dll'
Loaded plugin 'vrSAnimation.dll'
Loaded plugin 'vrSelectionModule.dll'
Loaded plugin 'vrSequencerModule.dll'
Couldn't read default preferences file 'C:\Users\Max\AppData\Roaming\VREDPro\simpleui.xml'!
Loaded plugin 'vrSUIScene.dll'
Loaded plugin 'vrSUIScenegraph.dll'
Loaded plugin 'vrSurfaceAnalysisModule.dll'
Uploading scene ...
Compling shaders ...
Compling shaders ready.
Uploading materials ...
Uploading materials ready.
Uploading geometries ...
Uploading geometries ready.
Uploading scene ready.
Loaded plugin 'vrTextureEditor.dll'
Loaded plugin 'vrTouchSensorModule.dll'
Loaded plugin 'vrTracking.dll'
Loaded plugin 'vrTransform.dll'
Loaded plugin 'vrTransformHelper.dll'
Loaded plugin 'vrVariants2.dll'
Loaded plugin 'vrVariantSets2.dll'
Loaded plugin 'vrVRMLViewPoints.dll'
Detected 1 cpu's with 4 cores and 8 logical cores.
Python 2.5.5 (r255:77872, Jun 24 2010, 14:38:20) [MSC v.1600 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license" for more information.
Loaded monitor profile 'C:\ProgramData\Autodesk\VREDPro-7.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded image profile 'C:\ProgramData\Autodesk\VREDPro-7.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded adobe rgb 98 profile 'C:\ProgramData\Autodesk\VREDPro-7.0\data\MonitorProfiles\AdobeRGB1998.icc'!
Loaded srgb profile 'C:\ProgramData\Autodesk\VREDPro-7.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded simpleGamma profile 'C:\ProgramData\Autodesk\VREDPro-7.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Creating default studio environment.
Initializing Studio as default studio environment material.
Initializing Environments as default environment material.
Initializing Shadow as default shadow material.
Loaded HDRLightStudioLive plugin.
HDRLightStudioLive: return version 7.
Initialized HDRLightStudioLive plugin.
Recreate HDRLightStudioLive plugin connections.
Startup time 29.699000 seconds
Couldn't read layout file 'C:\Users\Max\AppData\Roaming\VREDPro\materialeditor.matlayout'!
And the error log:
OS-Version: 6.0.6000 () 0x300-0x1
000000000A0C9CB2 (ig75icd64): (filename not available): DrvSetLayerPaletteEntries
000000000A0C9343 (ig75icd64): (filename not available): DrvSetLayerPaletteEntries
000000000A0CA838 (ig75icd64): (filename not available): DrvSetLayerPaletteEntries
0000000009FF985A (ig75icd64): (filename not available): RegisterProcTableCallback
0000000009FEF70D (ig75icd64): (filename not available): RegisterProcTableCallback
00007FFFEFC66E39 (OSGSystem): (filename not available): osg::SHLChunk::updateParameters
00007FFFEFC6A820 (OSGSystem): (filename not available): osg::SHLChunk::handleGL
00007FFFEFC4D47C (OSGSystem): (filename not available): osg::MField<osg::FCPtr<osg::FCPtr<osg::AttachmentContainerPtr,osg::ShaderParameter>,osg::ShaderParameterMMatrix>,0>::dump
00007FFFEFBB20CE (OSGSystem): (filename not available): osg::Window::validateGLObject
00007FFFEFC51640 (OSGSystem): (filename not available): osg::SHLChunk::activate
00007FFFF083CE10 (vrAABox): (filename not available): vrGlow::drawQuad
00007FFFF083D228 (vrAABox): (filename not available): vrGlow::drawFinal
00007FFFEC372B0D (vrOpenSGUberViewport): (filename not available): osg::UberViewport::noShadowRender
00007FFFEC3758B8 (vrOpenSGUberViewport): (filename not available): osg::UberViewport::render
00007FFFEE716DC6 (vrKernel): (filename not available): vrMaterialWidget::updateGL
00007FFFEE717696 (vrKernel): (filename not available): vrMaterialWidget::setMat
00007FFFE5EE6E83 (vrMaterialEditor): (filename not available): initvrMaterialEditor
00007FFFE5E808F5 (vrMaterialEditor): (filename not available): (function-name not available)
000000006E94A99E (QtGui4): (filename not available): QStyledItemDelegate::paint
000000006E8D892B (QtGui4): (filename not available): QListView::paintEvent
000000006E4BA886 (QtGui4): (filename not available): QWidget::event
000000006E7D2297 (QtGui4): (filename not available): QFrame::event
000000006E8BD975 (QtGui4): (filename not available): QAbstractItemView::viewportEvent
00007FFFE5E7FC9B (vrMaterialEditor): (filename not available): (function-name not available)
000000006F0BC8F3 (QtCore4): (filename not available): QCoreApplicationPrivate::sendThroughObjectEventFilters
000000006E472932 (QtGui4): (filename not available): QApplicationPrivate::notify_helper
000000006E475348 (QtGui4): (filename not available): QApplication::notify
00007FF61CDA2D3E (VREDPro): (filename not available): (function-name not available)
000000006F0BC782 (QtCore4): (filename not available): QCoreApplication::notifyInternal
000000006E4B8BAD (QtGui4): (filename not available): QWidgetPrivate::drawWidget
000000006E4AEFED (QtGui4): (filename not available): QWidgetPrivate::paintSiblingsRecursive
000000006E4B8D3C (QtGui4): (filename not available): QWidgetPrivate::drawWidget
000000006E4AEED7 (QtGui4): (filename not available): QWidgetPrivate::paintSiblingsRecursive
000000006E630A9D (QtGui4): (filename not available): QWidgetPrivate::invalidateBuffer_resizeHelper
000000006E4AE0FB (QtGui4): (filename not available): QWidgetPrivate::syncBackingStore
000000006E4BAC4D (QtGui4): (filename not available): QWidget::event
000000006E7C0BF0 (QtGui4): (filename not available): QDockWidget::event
000000006E472946 (QtGui4): (filename not available): QApplicationPrivate::notify_helper
000000006F0BE71C (QtCore4): (filename not available): QCoreApplicationPrivate::sendPostedEvents
000000006F0E33BF (QtCore4): (filename not available): QEventDispatcherWin32::event
00007FF80B5F2434 (USER32): (filename not available): DispatchMessageW
00007FF80B5F2297 (USER32): (filename not available): IsThreadDesktopComposited
000000006F0E505A (QtCore4): (filename not available): QEventDispatcherWin32::processEvents
000000006E4D3D35 (QtGui4): (filename not available): QApplicationPrivate::translateTouchEvent
000000006F0C03AA (QtCore4): (filename not available): QCoreApplication::processEvents
00007FFFEE698C00 (vrKernel): (filename not available): vrController::loop
00007FF61CDA647C (VREDPro): (filename not available): (function-name not available)
00007FF61CDA8981 (VREDPro): (filename not available): (function-name not available)
00007FF61CDB8210 (VREDPro): (filename not available): (function-name not available)
00007FF61CDA9107 (VREDPro): (filename not available): (function-name not available)
00007FF8096616AD (KERNEL32): (filename not available): BaseThreadInitThunk
00007FF80BDF4629 (ntdll): (filename not available): RtlUserThreadStart
I know I am just a Student, not a paying customer and my happyness is not Autodesk's numer one concern, but I would really like to use this software of which I thought it was cool, but since the latest release instantly crashed my opinion changed a bit.
I really hope for some help.
Thank you!
Best Regards,
Max
GeForce GT 750M
BTW: I solved the problem that the Material editor won't open up.
I just created the "AppData\Roaming\VREDPro\materialeditor.matlayout"-File.
But now I can't select any Material. As soon as I try to click on one VRED crashes.
Thanks for helping!
Tried installing the sp1?
If not, remember to search in the autodesk support center before.
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Yeah...
even with the SP1 installation it crashes at exact the same point.
Open VRED, open the Material editor and try to select one of the existing materials and it crashes.
This is a Showcase formum, so i don't have more help for you.
Sorry
This is a Showcase forum and you will most likely not find any technical help here.
I have not work with VRED myself and can't offer any help.
Good luck
Marion
this seems to be a GPU issue. I am assuming you are running on a notebook with optional Nvidia GPU. However, looking at the crash dump you see the crash happening in ig75icd64 which actually tells me VRED is running on the Intel GPU and not the Nvidia GPU. Sadly the Intel GPUs are known to be very unstable with VRED.
To get VRED up and running with the Nvidia-GPU you need to add the VRED application to the drivers 3D settings. Go to the Nvidia System Control panel, 3D Settings, add the VredPro.exe and set the GPU to use the "NVIDIA High Performanceprocessor".
Hope this solves the issue.
Kind regards
Michael
I have installed VRED PRO 2015
Unfortuantly VRED Crashes and i open the log file i recieve the log below
the laptop is 2 years old. i5 processor, intel hd400 graphics card
Log file from 11.08.2015 17:05:58
Loaded preferences from file 'C:\Users\Acer\AppData\Roaming\VREDPro\preferences.xml'!
vred kernel version 8.0 x64 (2015-03-09)
OpenGL version 4.000000 GLSL version 400
OS Version 6.2 service pack 0.0
Loaded 'vrKernelServices' library.
Loading Plugins ...
Loaded plugin 'vrAmbientOcclusionModule.dll'
Loaded plugin 'vrFinalRenderPass.dll'
QtWarning: QSplitter::setCollapsible: Index 1 out of range
QtWarning: Object::connect: No such signal QtGLenumPropertyManager::valueChanged(QtProperty *, const int)
QtWarning: Object::connect: No such signal QtGLenumPropertyManager::valueChanged(QtProperty *, UInt32)
Loaded plugin 'vrOpenPDMPlugin.dll'
Loaded plugin 'vrOverlayEditor.dll'
Loaded plugin 'vrPBAR.dll'
Couldn't find preferences file 'C:\Users\Acer\AppData\Roaming\VREDPro\simpleui.xml', created a new default file!
Uploading scene ...
Map Texture: Nothing selected.
Loaded plugin 'vrVredUi.dll'
Detected 1 cpu's with 2 cores and 4 logical cores.
Python 2.7.8 (default, Aug 20 2014, 09:53:46) [MSC v.1800 64 bit (AMD64)] on win32 Type "copyright", "credits" or "license" for more information.
QtWarning: QCoreApplication::postEvent: Unexpected null receiver
Loaded monitor profile 'C:\ProgramData\Autodesk\VREDPro-8.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded image profile 'C:\ProgramData\Autodesk\VREDPro-8.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded adobe rgb 98 profile 'C:\ProgramData\Autodesk\VREDPro-8.0\data\MonitorProfiles\AdobeRGB1998.icc'!
Loaded srgb profile 'C:\ProgramData\Autodesk\VREDPro-8.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
Loaded simpleGamma profile 'C:\ProgramData\Autodesk\VREDPro-8.0\data\MonitorProfiles\sRGB_IEC61966-2-1_black_scaled.icc'!
OpenGL renderer crashed, disabling rendering!
Startup time 153.993000 seconds
QtWarning: QWidget::repaint: Recursive repaint detected
i guess onboard graphics card is not up NVidia standards!
any advice on a solution or replacement graphics card
thanks
VRED does not support Intel GPUs, mainly because the drivers are very unstable.However, updating to the latest driver from the intel website might improve things (don´t use the manufactures drivers, these are usually old and bad).
Other than that you can only get a notebook with a better GPU. I would recommend an nvidia gpu since I have been using them for years but AMD should work fine as well. Sadly for ultrabooks (which I assume your current notebook is,considering it has a 3337U processor) your options are quite limited. But then, I would not really recommend to use VRED on an ultrabook anyways, they are not powerfull enough. I am sometimes running it on an asus ux303ln and it works ok if you are patient but I would not use it for serious work.
Kind regards
Michael
