So im in quiet the predicament.
Currently rendering several models on what i would say is a basic off teh shelf Quad core i7 ivy bridge computer.
My question is, and im not even sure if Showcase supports this.
Can showcase use Network rendering? There are several computers connected to the network, all of whice are in the same room. One of them has a license of Showcase 2014.
Could i have both those computers work on rendering the same Showcase file over the network?
read this post....
otherwise tou must use 3ds max.
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
HI,
Showcase doesn't support network rendering. You can load a different showcase scene on each computer and manually render each individual project but that is a lot of management.. sometimes worth it.. In this case, you can install the trial version of Showcase on all other computer which will give you access to Showcase for 30 days.
Good luck.
Share your project with us in the end if you can!
Marion
Hello there,
given you have acess to a Showcase Pro version many machines could
render a tile each. You will probably be able to save the output. Not ex-
actly what you expected- but it should work and you could make use of
three computers at once.
Kind regards
Daniel
