Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Showcase -> html with 3d control
2 REPLIES 2
sam_m
403 Views, 2 Replies
I know you can export from Showcase to html with a load of rendered vids of pre-defined motion, but is there any way to export to html and have it as a user-rotated 3d model like http://www.bikeconfig.com/ ?
basically - Showcase is great for presentations when the pc is in the room, but how can you export those presentations/models so they're accessible from outside the room?  across the world?  while still enabling more user-control than just pre-rendered videos?
I know Autodesk looked at this years ago with a dwf? plugin (sadly the project name escapes me) but as shown by that bike config tool technology and user-interaction has moved on, so what options are there available for us at present?  Obviously the visual quality won't be as good as a fancy render, but that bike config isn't bad...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
2 REPLIES 2
cikho
in reply to: sam_m
http://ggnome.com/object2vr
try this one!
also, showcase should export to html too, but you probably need a server to test it with
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
sam_m
in reply to: cikho
sorry for the late reply, I have been on holiday and then v busy.
The html export from Showcase, as far as I can tell, is pre-rendered animations and a nice html front-end to start playing each animation.
I'm asking how to export to an interactive format where the end-user can still rotate and zoom at their control, much like the old Autodesk project Freewheel (dwfit.com).  But, with Showcase's functionality of triggers and behaviours - e.g. click and drag to rotate the car, zooming in/out at will, then click on the door to have it open/close, etc.  Not pre-rendered animations, but 3d models within a website.
That object2vr looks kinda ok-ish, but as far as I can tell, it's just a glorified turntable, without wanting to belittle it.  How do you get the 3d control like that bike config website?  Given the nature that Showcase is intended to help with presentations and visualization of a product then surely there is a desire to allow this for overseas/global presentations where a web-format would be ideally suited?
Sam M.
