Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Problem with Replace object
1 REPLY 1
plembourg
753 Views, 1 Reply
Hello i need to replace lots of objects in my scene by others.
The problem is that when i replace an object by an other, the new one don't keep the position.
All replaced part arrived at 0,0,0...?
Does anyone has a solution to keep original position of the object replaced?
Thanks.
1 REPLY 1
fravat
in reply to: plembourg
There's no solution - cause the part you replace come to the origine of the file (not in the position of your initial object).
Maybe try the following:
-select a part with good position in your scene.
-press ctrl + shift + C (copy position)
-select the new imported item
-press ctrl + shift + V (paste position)
i wish it help !
