How do you import an image to use as a background in Showcase (2015)? / Where can you download the correct panoramic type of image?
I would like this for commercial use
Cheers,
Graham
Solved by MarionLandry. Go to Solution.
Solved by cikho. Go to Solution.
More information for you.
There are 3 ways to think about your question:
Option 1:
You need to find a royalty free image or purchase an image only. It need to be an HDRI Longitunal image. There is a wealth of HDRI longitunal image available on the internet for free and for sale. You will need to do this under the lighting Tab of the environment properties.
Option 2: it is possible to load just a background image in the viewport. This will also affect the material reflection as the material will reflect the background image. This image doesn't have to be HDRI but need to be longitunal.
You will do that under the Background tab of the Environment properties
Option 3: You can choose to render your image as a PSD file and change the background in Photoshop.
Rendering a PSD file will separate the object, the shadow and the environment in 3 different layer giving you the option to replace the environment by any image you like.
Hope this helps Clarify things further for you.
Marion
You can look at the process in this video: http://youtu.be/ar0VivUjXqI
Marion
Hi Marion,
You seem to know what your talking about so just another quick question...
I need to import a image for a Football Stadium into showcase. For this to work I need a radiance file (.hdr) extension.
Do you know of a converter that actually saves a jpeg (or several) into a hdri file? with the extension .hdr
Alternatively a good site to download an image like this?
Graham
You won't be able to do that actually. The HDRI image are built of multiple images at different light exposure. The HDRI images containt light information. A JPG does not. There is a lot of information out there on how to create a HDRI image.
This is one example http://youtu.be/OD_p9bTpbQ4
I just want to load an image HDRI like Lighting image and the same HDRi for the background, but not load, I can´t see the background and somecases the lighting not show to.
And how is the best process to create this Background, I can use whatever HDRI image?, or I need and specific parameter.
And for the background what could be the best practice to do this?
