So im trying to create a color that matches or closesly ressembles the color on the part shown in the picture.
Ive gone through just about all the showcase materials and tweaked them trying to get as close as possible.
But i feel ive exhausted all my knowledge on creating a custom material.
Any help or suggestions would be greatly offered.
Note that the color does not have to exactly match but just be close.
This problem is similar to this post
http://forums.autodesk.com/t5/General/Ray-tracing-of-metal-parts/m-p/4896582#U4896582
Maybe you can post what you have already tried, so we can try other settings....
This is what i have tried.....
But one thing that a think is the big problem is the imperfection of the model. Cad model has perfect surfaces, the model in the photo has imperfect surfaces and fillets... this can change the perception of the color and reflections.
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
quickest method for an approximation would be to use the steel satin hammered, or at the least the bump map from that material (might even need to modify it a bit in PS or the GIMP). Otherwise a normal map similar to this would be a decent starting point. and be sure to set the scale of the 'texturing' coreectly in order to see the effect.
if you want the bubbles from the casting too... well then you'll need to create your own normal map and position it correctly for your lighting scenario... in order to make them 'inny' rather than 'outy'... 😉
