When I create a behavior with a new pivot point, it rotate by another pivot point, seem like the pivot point of the scene instead of the objet. It only happened in one job. Is there a command i did wrong? I would use "Insert", G the S to snap to the corner, for example to open a door.
Judy
did you work with groups (in the object lister) and maybe changed the pivot of a certain object after putting it in the behavior list of objects?
because sometimes it screws up the whole animation..
and as far as i know is quite difficult to have it solved..
i don't know if this is the case, but what happened to me, was that i had the door animation to work initially, then somehow moved the group object tree, and after that the door started rotating in a completely different way. starting and ending in the exact position i have specifyed but rotating around a completely different pivot.
what i can suggest (but i've nevere tryed) is to completely reset all transformations..
Hi Judy,
wow.. it's really hard to know what exactly you are talking about without seeing some visuals..
I have recorded a small video of the behavior creation with the file you have sent me.
It is always a good idea to record the action with Jing and send a quick video.. other wise.. I have no idea what you are talking about.
What I did in the video is:
1-Select the door - now if you have multiple object you want to rotate all at once, You need to group them first and then select the group from the organizer
2-Press "insert" and change the pivot point to where it made sense- I used the snap tool
3-Create a behavior - not a turntable but a keyframe animation
4-Add keyframe for open and close states.
bingo: http://screencast.com/t/ZTb43j9wezfh
Does someone found something for this ? I'm having the exact same problem...
Here's a screencast :
Hy,
in the transform properties, try to press "center pivot" and "move to natural pivot" several times before to change your pivot point.
sometimes works...
http://forums.autodesk.com/t5/general/keyframe-position-error/m-p/5157453#M2190
bie
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Thanks for that tip.
I'll try it out.
I found out WHY the bugs occurs in my case.
I was placing a window, and because i have several different sizes, i used the scale in Showcase.
But i didn't made uniform scale, in fact i changed X and Z scale, but Y scale stayed the same. After that change, the pivot problem started to occur.
To correct this i had to use Inventor to scale objects before puting them at the right scale, and everything went fine after that.
