where is the Logic OP , Flame 2014
info
info
Hi
Why make disappear the logicOP on flame 2014 .
It was such a simple and practical tool.
I do not understand , knowing that there is so much to improve on this software.
J
Flame 2014/ Z820
Flare 2014/Z620
Smoke2013/MacPro
joelosis
It was replaced with the new COMP node, takes a little while to get used to but way better than the logic op in my opinion.
I´ve discover a little tip for the LOGIC OP node. I miss it!
If you wanna use it on Flame 2014:
1_ Just open one OLD BATCH SETUP from 2012 or 2013 version. which is included a LOGIC OP node,
    (for example: two clips, your logic op node and a render node).
    You will notice the LOGIC OP buble on your batch desk, BECAUSE 2014 can read old batchs and their nodes, although they won´t be included in the bin layout.
2_Then drag the LOGIC OP node to your USER BIN and save your preferences.
3_ Every time you will open your batch it will be included in that small window. Instead, load your user preferences. Smiley Happy.
info
Great cheers
